Custom integration for file editor. Useful for home assistant docker
Blueprint Studio - A Modern File Editor for Home Assistant :rocket:
Category: Integrations
Tags: integration #editor yaml #custom-component hacs
Hey everyone! :waving_hand:
I’m excited to share Blueprint Studio, a new custom integration I’ve been working on that brings a professional, VS Code-like file editing experience directly into your Home Assistant dashboard.
:thinking: The Problem
We’ve all been there - you need to quickly edit a YAML file, tweak an automation, or fix a configuration error. Your options are usually:
  • SSH into your system
  • Use an external SFTP client
  • Install a heavy add-on like VS Code Server
  • Use the basic File Editor add-on
What if you could just… edit files directly in Home Assistant with a modern, powerful editor? That’s why I built Blueprint Studio.
:sparkles: What is Blueprint Studio?
Blueprint Studio is a custom integration that adds a full-featured code editor to your Home Assistant sidebar. Think VS Code, but built right into your HA interface.
Blueprint Studio HACS HA
:bullseye: Key Features
Professional Editor
  • :white_check_mark: Syntax highlighting for YAML, JSON, Python, JavaScript, HTML, CSS, Markdown, Shell
  • :white_check_mark: Real-time YAML validation - Catch errors before you save!
  • :white_check_mark: Multi-tab interface - Edit multiple files at once
  • :white_check_mark: Code folding, bracket matching, line numbers
  • :white_check_mark: Search and replace functionality
  • :white_check_mark: Keyboard shortcuts (Ctrl+S to save, Ctrl+F to search, etc.)
File Management
  • :white_check_mark: File tree explorer with expandable folders
  • :white_check_mark: Create, delete, rename, copy, move files and folders
  • :white_check_mark: Upload files or entire folders (ZIP support)
  • :white_check_mark: Download files or folders as ZIP archives
  • :white_check_mark: File search to quickly find what you need
Security & Safety
  • :locked: Admin-only access - Only administrators can use it
  • :shield: Path protection - Can’t access files outside config directory
  • :page_facing_up: File type restrictions - Only edit safe text files
  • :locked_with_key: Critical file protection - Can’t delete configuration.yaml or secrets.yaml
  • :sunglasses: Hidden sensitive folders - .storage and other critical directories are hidden
Dark Theme
  • :crescent_moon: Clean, VS Code-inspired dark interface
  • :eye: Easy on the eyes for late-night config editing
  • :artist_palette: Syntax highlighting optimized for dark backgrounds
:wrench: Installation
Via HACS (Recommended)
  1. Add Custom Repository:
  • Open HACS
  • Go to Integrations
  • Click the three dots (⋮) → Custom repositories
  • Add: https://github.com/soulripper13/blueprint-studio
  • Category: Integration
  1. Install:
  • Search for “Blueprint Studio” in HACS
  • Click Download
  • Restart Home Assistant
  1. Configure:
  • Go to Settings → Devices & Services → Add Integration
  • Click to add
  1. Access:
  • Look for “Blueprint Studio” in your sidebar
  • Start editing!
Manual Installation
Download from GitHub Releases, extract to custom_components/blueprint_studio, restart, and add via integrations.
:graduation_cap: Use Cases
Here’s what I’ve been using it for:
  • :pencil: Quick edits to automations.yaml without restarting SSH
  • :magnifying_glass_tilted_left: Debugging integration configurations with syntax highlighting
  • :memo: Creating and editing Lovelace dashboard YAML
  • :bug: Fixing YAML syntax errors with real-time validation
  • :package: Backing up configs by downloading folders as ZIP
  • :rocket: Testing new automations in a separate file before merging
What would you use it for?
:vs_button: How Does It Compare?
| Feature | Blueprint Studio | File Editor (Add-on) | VS Code Server | SSH/SFTP |
| Installation | Custom Component | Add-on | Add-on | External |
| Resource Usage | Lightweight | Low | High | Minimal |
| Interface | VS Code-like, Multi-tab | Simple, Single file | Full VS Code | Terminal |
| YAML Validation | :white_check_mark: Built-in | :cross_mark: | :white_check_mark: Extensions | :cross_mark: |
| File Management | :white_check_mark: Full | :warning: Basic | :white_check_mark: Full | :white_check_mark: Full |
| Learning Curve | Low | Very Low | Medium | High |
:keyboard: Keyboard Shortcuts
One of my favorite features - familiar shortcuts that just work:
  • Ctrl+S / Cmd+S - Save file
  • Ctrl+Shift+S - Save all open files
  • Ctrl+F - Search in file
  • Ctrl+H - Search and replace
  • Ctrl+G - Go to line
  • Ctrl+/ - Toggle comment
  • Ctrl+W - Close tab
  • Ctrl+Z - Undo
  • Ctrl+Y - Redo
:bug: Known Issues & Limitations
Being transparent about current limitations:
  • No light theme yet - Dark theme only (planned for v1.1)
  • No git integration - Can’t commit changes directly (planned for future)
  • Admin only - By design for security, but means non-admin users can’t use it
  • Config directory only - Can’t edit files outside HA config (security feature)
:world_map: Roadmap
I’m actively developing and have plans for:
  • :sun_with_face: Light theme option
  • :gear: Configurable editor settings (font size, tab size, etc.)
  • :counterclockwise_arrows_button: File diff viewer
  • :bar_chart: Git integration for version control
  • :magnifying_glass_tilted_left: Search across all files
  • :floppy_disk: Built-in backup/restore
  • :scroll: File history/versioning
What features would YOU like to see? Drop your ideas in the comments!
:handshake: Looking for Feedback!
This is v1.0.0 - the first stable release. I’ve tested it extensively on my own system, but I’d love to hear from the community:
  • :bug: Bug reports - If something breaks, please let me know!
  • :light_bulb: Feature suggestions - What’s missing? What would make it better?
  • :camera_with_flash: Screenshots - If you install it, share screenshots!
  • :star: General feedback - Too simple? Too complex? Just right?
I’m very open to contributions and suggestions. This is for the community, so your input matters!
:books: Documentation & Links
:folded_hands: Acknowledgments
Big thanks to:
  • CodeMirror for the excellent editor library
  • The HA Community for inspiration and feedback during development
  • VS Code for design inspiration
  • Everyone who beta tested this!
:speech_balloon: Let’s Discuss!
I’d love to hear your thoughts:
  • Would this be useful for your setup?
  • What features are must-haves for you?
  • Any concerns about security or performance?
  • Have you tried it? How was your experience?
Drop a comment below and let me know what you think!
:glowing_star: Support the Project
If you find Blueprint Studio useful:
  • :star: Star it on GitHub - Helps with visibility
  • :loudspeaker: Share it - Tell others who might benefit
  • :bug: Report bugs - Help make it better
  • :light_bulb: Suggest features - Shape the roadmap
  • :handshake: Contribute - PRs welcome!
Thanks for reading, and happy editing! :rocket:
P.S. - This is my first public Home Assistant integration, so constructive feedback is especially welcome!
TL;DR: New custom integration that adds a VS Code-like file editor to Home Assistant. Multi-tab editing, YAML validation, file management, all from your HA dashboard. Available via HACS. Looking for feedback!
Great initiative! I’m giving it a spin, I was looking for an alternative to vscode and file editor
Great tool so far, I’ve recently gotten into HA and this is a great tool for my docker installation. Is there any plan for some auto-completion?
Thanks. I got tired of always have to open files externally for HA docker.
Hmm didn’t think of it. Will try to implement it. :grin:
Love it so far, please keep it going.
I’m waiting for my PR to review to make available in default HACS list.
I’ve implemented the auto completion and some other updates. Check it out and let me know
New Release is out with new features
Really nice! Great alternative to the resource-eating monster Studio Code :+1:
More new features and polishes added. Check it out. And spread the word. :grin:
I looked for that but couldn’t work out how. Pls guide me.
What do you mean? Just go to GitHub - soulripper13/blueprint-studio: Modern VS Code-like file editor for Home Assistant. Edit YAML configs with syntax highlighting, multi-tab support, and file management and click on :star: on the top right…
I’ve released a new minor update v1.3.1. There will a new one v1.3.2 also soon with new features that i’m curently testing and debugging. In a day or two.
# Blueprint Studio v1.3.2 Release Notes
This release introduces powerful visual tools for reviewing code changes, bulk file management, and a significantly upgraded search experience.
## ✨ New Features
### 📦 Bulk Download
*   **Select Multiple**: Enter selection mode via the new checklist icon to pick multiple files and folders.
*   **Auto-Zipping**: Click download to receive a single `.zip` file containing all your selected items, keeping directory structures intact.
### 🔍 Visual Diff Viewer (Integrated)
*   **Compare Changes Anywhere**: See exactly what you changed directly from the file explorer.
*   **Side-by-Side View**: Modified files now show a "Difference" icon in the tree; click it to see your current work vs the last commit.
*   **Color Coded**: Deletions are highlighted in red, additions in green, optimized for high readability in both Dark and Light themes.
### 🔎 Professional Search & Replace
We've significantly upgraded the search functionality to make finding and navigating code even easier!
*   **Enhanced Widget**: A new floating search tool with dedicated buttons for Next, Previous, Replace, and Replace All.
*   **Live Match Counting**: Instantly see "X of Y" matches (e.g., "1 of 10") in the search toolbar as you navigate.
*   **Distinct Active Highlight**: The currently selected match is now highlighted in vivid orange with black text.
*   **Smart Wrapping**: Search now automatically wraps around to the beginning (or end) of the file.
*   **Keyboard Shortcuts**: `Ctrl+F` to Find, `Ctrl+H` to Replace. Use `Enter` for next, `Shift+Enter` for previous.
### 🛡️ Optimized .gitignore Editor
*   **Clean & Efficient**: The exclusions manager now automatically detects redundant rules. If you ignore a folder, it won't clutter your `.gitignore` file with every single file inside it.
*   **Intelligent Toggle**: Background Git tasks and UI notifications now fully respect your Git Integration settings.
## 🚀 Improvements & Polish
*   **Enhanced Scrolling**: Improved the diff viewer behavior on smaller screens and mobile devices.
*   **Smart Selection**: Improved cascading checkbox logic for complex folder structures.
*   **Theme Optimization**: Fine-tuned colors for syntax highlighting and UI elements to ensure maximum readability.
