Português: Ao tentar me conectar em um HUAWEI WiFi AX3 Pro VER.A com o software 2.1.0.202 (C504) no HarmonyOS 3.0.3 esta simplesmente dando “Nome de usuário ou senha inválidos”, mas quando me conecto via browser ele acessa normalmente. Terias alguma dica do que pode esta ocorrendo?
English: When trying to connect to a HUAWEI WiFi AX3 Pro VER.A with software 2.1.0.202 (C504) on HarmonyOS 3.0.3 it’s simply saying "Invalid username or password ", but when I connect via browser it accesses normally. Do you have any tips on what might have happened?
To understand the cause of the problem, I will need additional logs.
The easiest way to get them looks like this:
Go to the integration settings and click “Enable debug logging”
Follow the steps that lead to the error
Click the “Disable debug logging” button, the log file will be downloaded automatically
In the downloaded file, delete all entries that do not relate to the integration of huawei mesh router (in principle, you can not do this if there is no private information in the logs)
If for some reason you cannot perform these actions, then there is a second option:
To enable debugging logs, you will need to make changes to the <home-assistant-config-folder->/configuration.yaml:
