Thanks for that. I’m guessing the one that is the bridge doesn’t show anything unique compared to the others does it?
For example, here the “primary” node (not bridged) shows the following - this is from Network Analyzer on Android (ultimately showing the same details). Interestingly none of the nodes show, but have in the past.
In all fairness, if the “primary” doesn’t announce itself in bridged mode it isn’t a big issue because you can always manually point to it. I was just wondering if I could make things easier for people.
That’s good. Each node reports itself in the device list with a mode. I use that mode to identify them as primary or secondary. I’ll assume that it doesn’t announce for now.
I’ll make some notes on what I’ve found and get the documentation updated accordingly.
I went to HACS and installed the linksys velop repository, but after restart I don’t find the integration when I try to add it to HA. Am I missing something??
New release pushed. Nothing new in there for anyone that already had it installed.
This one addresses the infinite spinning on login attempts when adding the integration.
For what it’s worth… 2 more errors are caught and handled appropriately. To be honest I have no idea why I didn’t catch these properly in the first place! I mean, I wrote the library that the integration uses and threw them in there! D’oh.
Hi, I’m really new to Home Assistant and I really don’t know how to install this custom integration.
I got 3 nodes that I would love to integrate into my setup. Can you please guide me as to how to install your integration.
Thank you in advance.
I would love to use your Lovelace card as well, but I have no idea where to paste / how to enable related code. If you could help with this, that would be much appreciated.
As per the README there’s a number of custom cards that are required for that layout. Have you installed all of those already?
If not, you’ll need to get those installed. If you have, then you may need to look at the troubleshooting guides for those cards to understand why they might not be available.
@uvjim, I am trying to install your custom component to HA 2021.10.5 with a Velop system running in bridge mode, but the installation is not finishing. It is just spinning indefinitely as it was mentioned above in one of the posts. Which version fixes that issue? Or how it can be installed?
Otherwise I cannot see anything in the log suggesting any issue.
