[Custom Integration] Mood Lights - A better way of managing mood lights!
Hey everyone! :wave:
I built a custom integration called Mood Lights and wanted to share it with the community.
:thinking: Why not just use Scenes?
Scenes work, but they have some pain points:
  • You can reconfigure them in Live mode, but the lights actually toggle at that time. → I needed a softer way to create moods for different vibes without annoying people.
  • There’s no quick way to “undo” a scene and go back to how your lights were before.
  • You have to set everything up front — no option to leave certain attributes untouched.
:sparkles: What Mood Lights does differently
:arrows_counterclockwise: Restore your lights automatically
  • When you activate a mood, it snapshots your current light states first.
  • One tap to go back to exactly how things were before.
  • No automations needed.
:gear: Fully reconfigurable from the UI
  • Change the name, swap lights in/out, tweak brightness or colors anytime.
  • No need to delete and recreate.
:dart: Only change what you want
  • Set brightness on one light, color temperature on another, and leave everything else alone.
  • If a field is left blank, that attribute stays untouched.
:bulb: Per-light control
  • Each light gets its own settings based on what it supports.
  • Brightness-only bulbs won’t show color pickers.
  • Lights with effects get an effect dropdown.
:rainbow: Effect support
  • If your lights support effects (like Rainbow, Candle, etc.), you’ll see a dropdown to pick one.
  • Select “None” to clear it.
:crescent_moon: Turn lights off too
  • Want some lights off as part of your mood? Just toggle them off.
  • Mix on/off states however you want.
:electric_plug: Exposes Actions
  • Trigger built-in options like applying moods or generating snapshots from automation workflows.
  • You can also use button.press actions.
:rocket: Installation
Install via HACS:
  • Open the link below and click the blue button
:point_right: GitHub: GitHub - pranjal-joshi/moodlights: Easy mood-based light management for Home Assistant · GitHub
:speech_balloon: Disclaimer
I’ve used AI as a co-pilot for rapid prototyping.
Would love to hear your feedback or feature ideas. Cheers! :tada:
Feel free to ‘Star’ this project on GitHub if you like it! :star:
Here are some screenshots you may want to take a look at before actually getting started.
