I’ve decided to implement proper tests for the config flow for my custom integration and I am slightly confused by the example scaffold code.
Does anyone know why the first test in the example calls:
await hass.async_block_till_done()
after the call to flow.async_configure
while none of the other tests do.
As an aside, one thing that I found that may be useful for others is that one now needs to define this fixture in conftest.py
for the tests to work…
import pytest
@pytest.fixture(autouse=True)
def auto_enable_custom_integrations(enable_custom_integrations):
yield
Thanks to the author of the sample test in pytest-homeassistant-custom-component
for helping me to work this out.
