Hi everyone,
I’ve released the first stable version of a new custom Home Assistant integration for TMT Automation / TMT Chow (ChowHUB) gate controllers.
The integration exposes the gate as native Home Assistant entities and allows both normal gate control and configuration of supported ChowHUB controller parameters directly from Home Assistant.
Current stable version: v1.0.1
Features
- Open, close and stop the gate
- Live gate state and position
- Battery monitoring
- Native Home Assistant
coverentity - Supported ChowHUB controller settings exposed as
selectentities - Read and modify controller parameters from Home Assistant
- Home Assistant Config Flow setup
- Diagnostics support
- Cloud push / MQTT runtime connection
- Usable in automations, scripts and dashboards
- 23 interface translations
The currently supported controller parameters include operation direction, automatic closing, safety device mode, operation speed, deceleration point and speed, overcurrent settings, pedestrian mode, flashing light, photocell settings, control button assignments, STOP input function and gate operation sequence.
Parameter changes are written to the controller and then read back again so Home Assistant reflects the confirmed controller state.
Installation
The integration can currently be installed through HACS as a Custom Repository.
Repository:
Latest release:
After installation and a Home Assistant restart:
Settings → Devices & services → Add integration → TMT Chow
Sign in with your TMT Chow account and select the gate you want to add.
Languages
The integration currently includes 23 translations: Bulgarian, Croatian, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Norwegian Bokmål, Polish, Portuguese, Romanian, Russian, Slovak, Slovenian, Spanish, Swedish, Turkish and Ukrainian.
v1.0.1
v1.0.1 is a small maintenance release that fixes the integration brand/icon files in the installable package. There are no functional changes to gate control, MQTT communication, controller parameters, diagnostics or translations compared with v1.0.0.
Disclaimer
This is an unofficial community integration and is not an official TMT Automation product.
Since a gate is a moving physical system, all physical safety devices such as photocells, obstacle detection and safety inputs should remain correctly installed, enabled and tested.
Testing and feedback from owners of other TMT Chow / ChowHUB controller models would be very welcome, especially regarding device compatibility and controller parameter support.
