Hi, Although I have a lot of programming experience, I am a totally newbie on both python and integration development for home assistant.
I would like to create a custom component/integration, but am a little bit stuck on setting up my project. I have created a devcontainer and now want to start with the instructions on Creating your first integration | Home Assistant Developer Docs.
I tried to run the “python3 -m script.scaffold integration” command, but first i got told to be in the project root. So my second attempt to try that in the /workspaces/hacore/homeassistant/components folder. Is this correct?
After running this command again in that folder, I get the following error:
File "<frozen runpy>", line 189, in _run_module_as_main
File "<frozen runpy>", line 112, in _get_module_details
File "/workspaces/hacore/homeassistant/components/script/__init__.py", line 5, in <module>
import asyncio
File "/usr/local/lib/python3.11/asyncio/__init__.py", line 8, in <module>
from .base_events import *
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 23, in <module>
import socket
File "/usr/local/lib/python3.11/socket.py", line 54, in <module>
import os, sys, io, selectors
File "/usr/local/lib/python3.11/selectors.py", line 12, in <module>
import select
File "/workspaces/hacore/homeassistant/components/select/__init__.py", line 5, in <module>
from datetime import timedelta
File "/workspaces/hacore/homeassistant/components/datetime/__init__.py", line 5, in <module>
from datetime import datetime, timedelta, timezone
ImportError: cannot import name 'datetime' from partially initialized module 'datetime' (most likely due to a circular import) (/workspaces/hacore/homeassistant/components/datetime/__init__.py)
Did I forgot something? Who can help me out to start my integration from a basic template?
