I can’t add a custom intent to my home assistant, the built in works.
It fails with Unexpected error during intent recognition.
What i did is create under the path custom_sentences/en/test.yaml that looks like this
language: "en"
intents:
Test:
- sentences:
- "Hello"
- "Hi"
Ping:
- sentences:
- "Ping"
And my configuration file looks like this
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
intent_script:
Test:
speech:
text: "Hello!"
Ping:
speech:
text: "Pong"
The error in the voice assistant manager looks like this
stage: done
run:
pipeline: 01hgfkazfk5y3fb9130mxak04w
language: en
runner_data:
stt_binary_handler_id: null
timeout: 300
events:
- type: run-start
language: en
runner_data:
timeout: 300
timestamp: "2023-11-30T14:48:12.763090+00:00"
- type: intent-start
engine: homeassistant
language: en
intent_input: Ping
conversation_id: null
device_id: null
timestamp: "2023-11-30T14:48:12.763157+00:00"
- type: error
code: intent-failed
message: Unexpected error during intent recognition
timestamp: "2023-11-30T14:48:12.779296+00:00"
- type: run-end
data: null
timestamp: "2023-11-30T14:48:12.779379+00:00"
intent:
language: en
intent_input: Ping
device_id: null
done: false
error:
code: intent-failed
What can i do to fix this issue?
