Custom javascript library to reuse in Button Card
HI,
I’d like to create a library of custom javascript functions to be reused in Button Card.
I created a common_functions.js file in /config/www.
I added a resource to lovelace for the created file. (/local/common_functions.js)
I created a simple example function in file common_functions.js:
function test_function(input) {
   var value = input + 1;
   return value;
I created an example card:
type: custom:button-card
     return test_function(10);
But button-card doesn’t see my custom function.
ButtonCardJSTemplateError: ReferenceError: test_function is not defined in 'return test_function(10);'
Any tips?
I’m trying to do the same. Have you found a solution for this?
unfortunately not
And now ? because i’m looking to that too :wink:
Custom button-card offers helpers object with functions prepared for formatting date/time values. Maybe thats the direction of considerations? Maybe it’s worth to take a look inside custom-button javascript code? If somebody has enough skills :slight_smile:
Is this suggestion or advice? Just curious because you are responding to a post from 9 months ago…
True. But I believe this is not a resolved issue and I’m very interested in getting a kick to some direction. My skills are not greate in javascript modules/resources, so I try to kick somebody else :slight_smile:
