Spartacus
(Spartacus)
April 12, 2024, 9:00am
1
I am again playing with template cards in a layout card. Is there a possibility to reduce the line spacing?
The current code:
type: custom:stack-in-card
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 1fr 1fr 1fr
grid-template-rows: auto
margin: null
cards:
primary: 'Lichtschranke: {{ ''Reset Alarm'' if states(entity) == ''on'' else ''ok'' }}'
multiline_secondary: true
secondary: ''
layout: null
icon: >-
{{ 'mdi:alarm-light-outline' if states(entity) == 'on' else
'mdi:alarm-light-off-outline' }}
tap_action:
action: call-service
service: input_boolean.turn_off
entity_id:
- input_boolean.alert_ir_blocked
data: {}
icon_color: '{{ ''red'' if states(entity) == ''on'' else ''grey'' }}'
badge_icon: ''
fill_container: false
entity: input_boolean.alert_ir_blocked
badge_color: ''
card_mod:
style:
mushroom-shape-icon$: |
.shape
--icon-symbol-size: 20px;
--icon-size: 40px;
--shape-color: transparent !important;
{% set state = states(config.entity) %}
{% if state == 'on' %}
--shape-animation: ping 2s infinite, wobbling 0.5s linear infinite alternate;
{% else %}
{% endif %}
@keyframes ping
0% {box-shadow: 0 0 0 0 #DC143C }
90% {box-shadow: 0 0 0 3px transparent;}
100% {box-shadow: 0 0 0 0 transparent;}
@keyframes wobbling
0% {transform: rotate(-10deg);}
100% {transform: rotate(10deg);}
mushroom-state-info$: |
.container {
--card-primary-font-size: 14px;
ha-card
border: none !important;
{% if is_state(config.entity,'on') %}
--card-primary-color:
{%else%}
--card-primary-color: green;
{% endif %}
primary: |-
IR-Sender:
{{ 'ALARM' if (states("input_boolean.alert_ir_blocked") == 'on') else
'aus' if (states(entity) == 'off') else
'ein' if (states(entity) == 'on')
layout: null
secondary: >-
{{'bitte zurücksetzen' if states("input_boolean.alert_ir_blocked")==
'on'}}
icon: mdi:leak
tap_action:
action: toggle
icon_color: '{{ ''green'' if states(entity) == ''on'' else ''#636363'' }}'
badge_icon: >-
{{'mdi:exclamation' if states("input_boolean.alert_ir_blocked")==
'on'}}
badge_color: '#DC143C'
entity: switch.k05_ir_sender
double_tap_action:
action: none
hold_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
--shape-animation: ping 2s infinite;
{% else %}
{% endif %}
{% if states("input_boolean.alert_ir_blocked")== 'on' %}
box-shadow: 0 0 0 1px #DC143C !important
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
--card-primary-color: #E0E0E0;
--card-secondary-color:#DC143C;
primary: |-
IR Empfänger:
'detect' if (states(entity) == 'on') else
'aus' if (states("switch.k05_ir_sender") == 'off') else
'idle' if (states("switch.k05_ir_sender") == 'on')
layout: null
secondary: >-
states("input_boolean.alert_ir_blocked")=='on'}}
icon: mdi:leak
tap_action:
action: none
icon_color: |-
{{ '#636363' if (states("switch.k05_ir_sender") == 'off') else
'amber' if (states(entity) == 'on') else
'green' if (states("switch.k05_ir_sender") == 'on')
badge_icon: >-
entity: input_boolean.delay_ir_detection
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
primary: 'Haustür: {{ ''Reset Alarm'' if states(entity) == ''on'' else ''ok'' }}'
layout: null
secondary: ''
icon: >-
tap_action:
entity_id:
- input_boolean.alert_open_door
data: {}
badge_icon: ''
entity: input_boolean.alert_open_door
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card
{%else%}
{% endif %}
primary: |-
Haustür:
{{ 'ALARM' if (states("input_boolean.alert_open_door") == 'on') else
'geschlossen' if (states(entity) == 'off') else
'geöffnet' if (states(entity) == 'on')
layout: null
secondary: >-
{{'bitte zurücksetzen' if states("input_boolean.alert_open_door")==
'on'}}
icon: '{{ ''mdi:door-open'' if states(entity) == ''on'' else ''mdi:door-closed'' }}'
tap_action:
action: toggle
icon_color: '{{ ''amber'' if states(entity) == ''on'' else ''green'' }}'
badge_icon: >-
{{'mdi:exclamation' if states("input_boolean.alert_open_door")==
'on'}}
entity: binary_sensor.reed_input
card_mod:
style:
.shape
--icon-size: 40px;
{% set light_state = states(config.entity) %}
{% if light_state == 'on' %}
{% else %}
{% endif %}
{% if states("input_boolean.alert_open_door")== 'on' %}
{% else %}
{% endif %}
@keyframes ping
0% {box-shadow: 0 0 0 0 #FFC107 }
.container {
ha-card{
card_mod:
style:
ha-markdown $: |
img {
vertical-align: bottom !important;
ha-card
card_mod:
style: |
ha-card {
Like this…
cards:
layout:
cards:
secondary: ''
icon: >-
tap_action:
entity_id:
data: {}
badge_icon: ''
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card
{%else%}
{% endif %}
primary: |-
IR-Sender:
secondary: >-
'on'}}
icon: mdi:leak
tap_action:
action: toggle
badge_icon: >-
'on'}}
double_tap_action:
action: none
hold_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
primary: |-
IR Empfänger:
icon: mdi:leak
tap_action:
action: none
icon_color: |-
badge_icon: >-
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
secondary: ''
icon: >-
tap_action:
entity_id:
data: {}
badge_icon: ''
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card
{ margin-top: -40px;
{%else%}
{% endif %}
primary: |-
Haustür:
secondary: >-
'on'}}
tap_action:
action: toggle
badge_icon: >-
'on'}}
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
margin-top: -40px;
card_mod:
style:
ha-markdown $: |
img {
ha-card
card_mod:
style: |
ha-card {
Spartacus
(Spartacus)
April 12, 2024, 3:53pm
4
Now I wanted to add a divider between the topics and I found the text-divider card and installed the lines (Test)
it is working, but I cannot modify any parameters, like I can do it in this example:
cards:
layout:
grid-template-columns: 1fr 1fr 1fr 1fr 1fr
margin: null
cards: null
- type: entities
entities:
- type: custom:text-divider-row
text: Text
card_mod:
style: |
:host {
--text-divider-line-size: 5px;
--text-divider-color: red;
--text-divider-font-size: 10px;
--text-divider-margin: 0px 4px 40px 64px;
The code where I want to change the divider!
Also the position of the first divider cannot be moved a little bit up! Maybe you see, what is wrong in the code below!
type: custom:mod-card
card_mod:
style:
hui-horizontal-stack-card $: |
hui-vertical-stack-card:nth-of-type(1) {
flex-grow: 1.3 !important;
hui-vertical-stack-card:nth-of-type(2) {
flex-grow: 2.0 !important;
card:
type: horizontal-stack
cards:
- type: vertical-stack
cards:
- type: custom:stack-in-card
cards:
primary: 'Eingang:'
secondary: >-
{% set months = ["Januar", "Februar", "März", "April", "Mai",
"Juni", "Juli", "August", "September", "Oktober", "November",
"Dezember"] %}
{% set days = ["Montag", "Dienstag", "Mittwoch", "Donnestag", "Freitag", "Samstag", "Sonntag"] %}
{{ days[now().weekday()] }}, der {{ now().day | string }}. {{ months[now().month-1] }}
{{ states("sensor.time") }} Uhr
icon: mdi:arrow-left-bold-outline
tap_action:
action: navigate
navigation_path: /dashboard-christian
icon_color: ''
card_mod:
style: |
ha-card {
--card-primary-font-size: 1.8rem;
--card-primary-font-weight: normal;
--card-secondary-font-size: 1.0rem;
--card-primary-line-height: 2.0;
--card-secondary-line-height: 1.5;
--primary-text-color: #E0E0E0;
--secondary-text-color: #808080;
--card-mod-icon-color: green;
font-family:'roboto';
border: none;
box-shadow: none;
margin-top: 0.0rem;
## background:none;
text: Test
layout:
cards:
primary: >-
Lichtschranke: {{ 'Reset Alarm' if states(entity) == 'on'
else 'ok' }}
secondary: ''
icon: >-
tap_action:
entity_id:
data: {}
badge_icon: ''
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card{ margin-top: -30px;
{%else%}
{% endif %}
primary: >-
IR-Sender:
'on') else
secondary: >-
states("input_boolean.alert_ir_blocked")== 'on'}}
icon: mdi:leak
tap_action:
action: toggle
badge_icon: >-
double_tap_action:
action: none
hold_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
primary: |-
IR Empfänger:
multiline_secondary: >-
true
icon: mdi:leak
tap_action:
action: none
icon_color: >-
else
badge_icon: >-
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
layout:
cards:
primary: >-
Haustür: {{ 'Reset Alarm' if states(entity) == 'on' else
'ok' }}
secondary: ''
icon: >-
tap_action:
entity_id:
badge_icon: ''
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card
{%else%}
{% endif %}
primary: >-
Haustür:
'on') else
secondary: >-
states("input_boolean.alert_open_door")== 'on'}}
icon: >-
{{ 'mdi:door-open' if states(entity) == 'on' else
'mdi:door-closed' }}
tap_action:
action: toggle
badge_icon: >-
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
margin-top: -30px;
text: Test
- type: markdown
content: >-
<ha-icon icon="mdi:weather-sunset-up"></ha-icon>
|• <ha-icon icon="mdi:weather-sunset-up"></ha-icon>
Sonnenaufgang:|**{{(state_attr('sensor.home_sun_dawn','today')).strftime('%H:%M')}}**
Uhr
|• <ha-icon icon="mdi:weather-sunset-down"></ha-icon>
Sonnenuntergang:|**{{(state_attr('sensor.home_sun_dusk','today')).strftime('%H:%M')}}**
Uhr
Spartacus
(Spartacus)
April 15, 2024, 7:02am
6
Hi all,
I didn´t get this working in the code above. I implemted this code:
- type: entities
entities:
text: Text
card_mod:
style: |
:host {
.text-divider { --text-divider-margin-top: -40px; }
and the line doesn´t move. There is also a border which I cannot remove.
any ideas?
You are stacking card on top of cards and it’s not necessary. This is especially true if you are using grid layout cards inside those stacks. Id suggest getting your layout set them expanding the code.
Is the information in you cards changing drastically enough for the flex grow code you have using the mod-card at the top?
card_mod:
style:
card:
cards:
cards:
cards:
xxxxxx
layout:
Spartacus
(Spartacus)
April 15, 2024, 7:46am
8
I am not really sure, what you mean!
let me explain the use case:
all cards in the stack should not have a border
the grid template was stacked twice, because it was not possible to alignt to rows with different colums (Lichtschranke 3 colums, Haustür 2 colums)
the functional-area with the device (Lichtschranke/Haustür) should be decoupled with a divider from other functional areas, which I will add later.
If I understand correctley, I cannot use two differnt grids in one stack, or what do you mean?
A grid is a grid. You can align the columns
cards:
layout:
margin: 0px 0px 0px 0px
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.test
card_mod:
style: |
ha-card {
border: none;
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
card_mod:
style: |
ha-card {
border: none;
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
card_mod:
style: |
ha-card {
border: none;
- type: entities
entities:
text: Text
card_mod:
style: |
ha-card {
border: none;
layout:
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
card_mod:
style: |
ha-card {
border: none;
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
card_mod:
style: |
ha-card {
border: none;
Spartacus
(Spartacus)
April 15, 2024, 10:51am
10
thank you very much for your support. I think I have it now. What I did not understood was, that you need to modify the “entity-level” of the divider-row.
But how do you play with the margin? And what does the 4 columns mean (0px 0px 0px 0px)
cards:
primary: 'Eingang:'
secondary: >-
{% set months = ["Januar", "Februar", "März", "April", "Mai", "Juni",
"Juli", "August", "September", "Oktober", "November", "Dezember"] %}
tap_action:
action: navigate
icon_color: ''
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin-top: 0.0rem;
## background:none;
- type: entities
entities:
text: Text
card_mod:
style: |
:host {
--text-divider-line-size: 2px;
# --text-divider-color: red;
--text-divider-margin: -30px;
border: none;
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
layout:
cards:
secondary: ''
icon: >-
tap_action:
entity_id:
data: {}
badge_icon: ''
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card{ margin-top: -35px;
{%else%}
{% endif %}
primary: |-
IR-Sender:
secondary: >-
'on'}}
icon: mdi:leak
tap_action:
action: toggle
badge_icon: >-
'on'}}
double_tap_action:
action: none
hold_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
primary: |-
IR Empfänger:
true
icon: mdi:leak
tap_action:
action: none
icon_color: |-
badge_icon: >-
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
layout:
cards:
secondary: ''
icon: >-
tap_action:
entity_id:
badge_icon: ''
badge_color: ''
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
@keyframes wobbling
.container {
ha-card
{%else%}
{% endif %}
primary: |-
Haustür:
secondary: >-
'on'}}
tap_action:
action: toggle
badge_icon: >-
'on'}}
card_mod:
style:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
margin-top: -35px;
- type: entities
entities:
text: Text
card_mod:
style: |
:host {
--text-divider-margin: -35px;
border: none;
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
Spartacus
(Spartacus)
April 15, 2024, 6:59pm
12
Hi all,
I still have problems with the alignment of the transcripts. How does the margin work? How can I move the “Schalzeiten” to the left?
cards:
cards:
layout:
margin: auto
cards:
primary: 'Eingang:'
secondary: >-
"Mai", "Juni", "Juli", "August", "September", "Oktober",
tap_action:
action: navigate
icon_color: ''
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin-top: 0.0rem;
## background:none;
- type: markdown
content: >-
Uhr
Uhr
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin-top: 0px;
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
