This setup uses browser-mod as well, right? Then just use browser-mod for the AlarmPanel popup.
I’m not sure about auto closing but there probably is a way. Interesting idea though.
Hi Dbuit and all the other you guys could help me understand why despite having correctly used the instructions that I enclose, I get this image instead of the one that is on the page: https://github.com/DBuit/cover-popup-card
I followed to the letter what is described in the github page, but what I get is the first image attached very different from the github one. Can you help me?
A little update reading and rereading your posts I realized that the problem I reported here only occurs with FIREFOX, while with Android and Chrome it works perfectly. Could you help me and suggest what modification I need to make to see the slider correctly on FIREFOX. Thank you all
Thanks @mkhattab - although that doesn’t quite work for me. For some reason, the background-colour and text-colours are ignored, and I can’t get the glow working in this way.
Is there a summary somewhere of all the variables that we can refer to in the style: area?
@thecrane I have been trying to find a reference for customisable variables as well because there are other things I’d like to change. Please share if you find anything and I’ll do the same as well
Look at https://github.com/DBuit/Homekit-panel-card and search for Css variables and default values
That are the variables, and if something is not changing try to add !important to overwrite old css with your css.
Hi could you post me the code you used to display MIN and MAX temperature and the time when they occurred? I imagine that there is an ad hoc code that detects these values and that written in the configuratio.yaml because I do not see it in the CARD Thanks
Is it just for me that 116 brakes this card? I get just a blank page and when i edit the card everything show upp. Yes i cleard the page cashe 10 times.
