Custom Lovelace Card - Homekit style card
I was finally able to figure out a way to get the switch popup card as a FAN and non popup. I had to use the custom:hui-element and Custom:layout-card. but works flawlessly.
type: 'custom:layout-card'
entities:
  - type: 'custom:hui-element'
    card_type: 'custom:switch-popup-card'
    entities:
      - fan.master_bedroom_fan
    buttons:
      - icon: 'mdi:fan'
        value: high
        color: '#FFF'
        icon_color: 'rgba(255,255,255,1)'
      - icon: 'mdi:fan'
        value: medium
        color: '#FFF'
      - icon: 'mdi:fan'
        value: low
        color: '#FFF'
      - icon: 'mdi:fan-off'
        value: 'off'
    icon: mdi-fan
    noActiveState: '-'
    entity_value_path: attributes.speed
    service: fan.set_speed
    service_data:
      entity_id: this
      speed: value
Hello! I’m trying to use switch-popup-card to implement a good looking “hold_action” for my alarm. Because I’m not using the Homekit Style Card, I’ve used browser mod to create the popup. The problem that I’m facing is that, the hass call service to arm/disarm my alarm is failing with the following error:
Failed to call service alarm_control_panel/alarm_disarm. must contain at least one of entity_id, area_id.
I’m specifying the entity_id and the code needed to arm/disarm the alarm on each button. Here you have the code:
              - type: custom:switch-popup-card
                entity_value_path: state
                fullscreen: false
                entities:
                  - '[[[ return entity.entity_id ]]]'
                buttons:
                  - icon: "mdi:lock"
                    value: "armed_away"
                    color: "#FFF"
                    icon_color: "rgba(255,255,255,1)"
                    service: alarm_control_panel.alarm_arm_away
                    service_data:
                      entity_id: '[[[ return entity.entity_id ]]]'
                      code: !secret alarm_code
                  - icon: "mdi:lock"
                    value: "disarmed"
                    color: "#FFF"
                    service: alarm_control_panel.alarm_disarm
                    service_data:
What am I doing wrong?
Thanks!!
Hi @asierralozano,
Not sure what this is: [[[ return entity.entity_id ]]]
But inside the card for the service_data you can also use entity_id: this try if that works.
It looks that it works! Thanks!
Hello Guys,
Just released small update: https://github.com/DBuit/Homekit-panel-card/releases/tag/0.4.9.5
  • Fix for useBrightness and useTemperature
  • Add option to replace icon by image and offImage for when the tile is in off state
  • Add missing style graph tile for unit of measurement,
  • Brightness slider in tile is now also be used on larger tiles with the wider / higher options
Works like a charm! Is way better now!
Btw, I found that:
style: |
  :host {
    --tile-background: rgba(230,230,225,0.7);
    --tile-on-background: white;
looks really close to the original colors (in case anyone will need this)
Thanks again!
Great work! I have two questions which im struggling with and where i hope you could help.
  • One big thing im missing is a lock feature just like with the button card. With this i can prevent that me or my wife push something we don’t want to push by accident. Is this something you are going to add?
  • Secondly, is it possible to combine the homekit card together with other cards on the same view? I found one workaround with the layout card but then my layout is screwed with homekit. What i want to do is to combine the homekit buttons for my lights and use double gauge card for example to show the current brightness/colortemp variable for circadian values
It keeps throwing errors at me or isn’t showing the homekit card, see below my test code:
title: TestHomekit
path: TestHomekit
panel: true
icon: mdi:home
cards:
  - type: custom:dual-gauge-card
    title: Test
    outer:
      entity:  sensor.tpl_clbrightness
      label: "1"
      min: 0
      max: 255
    inner:
      entity: sensor.tpl_clcolortemp
      label: "2"
      min: 0
      max: 500
    colors:
      - color: "var(--label-badge-yellow)"
        value: 100
      - color: "var(--label-badge-green)"
        value: 150
      - color: "var(--label-badge-blue)"
        value: 250
  - type: "custom:homekit-card"
    useBrightness: true
    useTemperature: true
    # titleColor: "#FFF"
    enableColumns: true
    statePositionTop: true
    style: |
      :host {
    rows:
      - row: 1
        columns:
          - column: 1
            # tileOnRow: 4
            entities:
              - title: Begane grond
                entities:
                  - entity: light.grp_beganegrond
                    spin: false
                    icon: bha:mirror-lamp
                    slider: true
                    popup:
                      type: custom:light-popup-card
                      scenesInARow: 2
                      brightnessWidth: 130px
                      brightnessHeight: 350px
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_toilet
                    icon: bha:ceiling-lamp
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_hal
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_woonkamer
                    icon: bha:led-strip
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_woonkamertv
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_trapkast
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_keukentafel
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_achterhoek
                    icon: bha:led-strip
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.bureaubeam01
                    name: Beam Achterhoek
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                    icon: bha:led-strip
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_bijkeuken
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
                  - entity: light.grp_benedensfeerlifx
                    name: Beneden sfeer Lifx
                    slider: true
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                      settings: true
When i include it into a homekit card it’s not showing correctly
      - row: 4
        columns:
          - column: 1
            # tileOnRow: 4
            entities:
              - title: Test
                entities:
                  - card: custom:mini-graph-card
                    noPadding: true
                    wider: true
                    cardOptions:
                      entities:
                        - entity: sensor.tpl_clcolortemp
                      line_color: '#1427ff'
                      hold_action:
                        action: none
                      tap_action:
                        action: none
                  - card: gauge
                    wider: true
                    noPadding: true
                    cardOptions:
                      unit: '%'
                      severity:
                        green: 0
                        yellow: 250
                        red: 450
                  - card: custom:dual-gauge-card
                    wider: true
                    higher: true
                    noPadding: true
                    cardOptions:
                      outer:
                        label: "1"
                        min: 0
                        max: 255
                      inner:
                        label: "2"
                        min: 0
                        max: 500
                      colors:
                          value: 100
                          value: 150
                          value: 300
Hi Dbuit,
First thanks a lot for your hard work, it’s really great addon to Home Assistant.
I have a ceiling fan with light and I just wonder if there is an option to show the “light-popup-card” together with “switch-popup-card” in order to be able to control the light and fan speed from the same popup screen, maybe something like this:
and one more thing, I ask you in the past if there is an option to use custom picture instead of icon and I will appriciate of you can please check if you can enable this kind of change.
Thanks in advanced.
Is there anyone that has problem that the Rules part wont load untill clicked on?
Or that it take extremly long time to load.
If i klick the part were the rules are it loads direkly. @DBuit
Can it be some Java thing of homeassistant causing this? Want me to make a video of it?
Is there a way of getting the image in the card to take up the whole card?
I’ve tried a couple of things mentioned above but no joy?
Code is
                      - entity: media_player.kitchen_display
                        name: Top Songs 2016
                        image: 'http://192.168.68.110:8123/local/2016playlisticon.png'
                        style: |
                          :host {
                          --tile-image-radius: 300%
                        tap_action:
                          action: call-service
                          entity_id: media_player.kitchen_display
                          service: spotcast.start
                          service_data:
                            device_name: Kitchen Display
                            offset: 1
                            random_song: true
                            repeat: track
                            shuffle: true
Thanks!
Hi @Eldudemeister,
at the moment it is no option but maybe not a bad idea.
For now you could fix it with the styles but than all images will go over the whole tile but maybe that is no problem for your.
Add this to style:
           :host {
                --tile-image-radius: 0;
          .icon.image {
            position: absolute;
            width: 100%;
            height: 100%;
            left: 0;
            top: 0;
            z-index: -1;
          .icon.image img {
              height: 100%;
Hi @tomerbs,
What you could try to do is use browser_mod (maybe you already have it?)
You can open any lovelace card as a popup.
Next you could use layout card i think and inside the layout card use the light popup, and switch popup so you have them both in 1 popup.
Hi @lubbertkramer,
About locking, you really want it with a password and stuff or just a tile where you can disable the actions when tapped?
About combining i have not done that but other people have i guess that is your best option, maybe scroll back there are people that got it working i think.
Really strange that gauge card is working so strange inside a tile, i guess some conflicting css i dont use that card what can you put in it maybe i can see what breaks it.
Thx for this post. Was pulling my hair on this one. Had no icons showing untill i used this.
This is the code in total im using on the Card
enableColumns: true
home: true
rules: |
  {% if states('sensor.current_lights_on') | float > 0 %}
  <li>{{states('sensor.current_lights_on')}} Lampor är på</li> {% endif %}
  {% if "unlocked" in states('lock.entre_dorr') %} <li>Dörren är EJ LÅST!!</li>
  {% if "disarmed" in states('alarm_control_panel.dammtorps_alle_lgh_alarm') %}
  <li>Larmet är:  avlarmat</li> {% endif %}
  {% if "triggered" in states('alarm_control_panel.dammtorps_alle_lgh_alarm') %}
  <li>Larmet larmar</li> {% endif %}
  {% if "armed_home" in states('alarm_control_panel.dammtorps_alle_lgh_alarm')
  %} <li>Larmet är i:  Skalskyddat läge</li> {% endif %}
  {% if "armed_away" in states('alarm_control_panel.dammtorps_alle_lgh_alarm')
  %} <li>Larmet är i:  Helskyddat läge</li> {% endif %}
  {% if "armed_night" in states('alarm_control_panel.dammtorps_alle_lgh_alarm')
  %} <li>Larmet är:  Nattlarmat</li> {% endif %}
  <li>Tempratur Hemma är runt {{states('sensor.vardagsrum_temperature') |
  round(1) }} °C</li>
  {% if "home" in states('person.jimmy') %} <li>Jimmy är Hemma</li> {% endif %}
  {% if "home" in states('person.Maria') %} <li>Maria är Hemma</li> {% endif %}
title: Home
icon: 'mdi:home-outline'
rows:
  - columns:
      - column: 1
        entities:
          - entities:
              - entity: sensor.vardagsrum_temperature
              - entity: input_boolean.fan
                spin: true
              - double_tap_action:
                  action: navigate
                  navigation_path: /lovelace/2
                entity: light.vardagsrums_lampor_grupp
                offStates:
                  - 'off'
                  - unavailable
              - entity: light.vardagsrum_vanster
                offStates:
                  - 'off'
                  - unavailable
              - entity: light.vardagsrum_hoger
                offStates:
                  - 'off'
                  - unavailable
                  - otillgänglig
                  - unknown
              - entity: switch.koks_fonster
              - entity: light.koket
                supportedFeaturesTreshold: 0
              - entity: binary_sensor.altandorr_vardagsrum
                icon: 'mdi:door-open'
                offIcon: 'mdi:door'
            popup:
              actions:
                - color: '#271a00'
                  service: scene.turn_on
                  service_data:
                    entity_id: scene.vardagsrum_movie_night
                - color: '#ffb424'
                  service_data:
                    entity_id: scene.familj_kvall
              actionsInARow: 2
              entities:
              settings:
                closeButton: stäng
                openButton: Inställningar
              supportedFeaturesTreshold: -1
              switchHeight: 300px
              switchWidth: 110px
            title: Vardagsrum
        tileOnRow: 4
      - column: 1
        entities:
          - entities:
              - entity: sensor.sovrummet_temperature
              - entity: light.sovrum_sang_vanster
              - entity: light.sovrum_sang_hoger
              - entity: light.sovrums_fonster
              - entity: light.sovrum_bank_vanster
              - entity: light.sovrum_bank_hoger
                  action: navigate
                entity: light.sovrumsbank_lampor_grupp
                  action: navigate
                entity: light.sovrums_temp_lampor_grupp
                title: |
                  [[[ return entity.attributes.friendly_name ]]]
            popup:
              actions:
                - color: '#00c788'
                  service_data:
                    entity_id: scene.gront_ar_skont
                - color: '#ff7200'
                  service_data:
                    entity_id: scene.mysigt
                - color: '#c4d9d2'
                  service_data:
                    entity_id: scene.spelande
                - color: '#f000ff'
                  service_data:
                    entity_id: scene.sexigt
              actionsInARow: 2
              entity: |
              settings:
                closeButton: stäng
              switchHeight: 300px
              switchWidth: 110px
              type: 'custom:light-popup-card'
            title: Sovrum
        tileOnRow: 4
    row: 1
  - columns:
      - column: 2
        entities:
          - entities:
              - entity: sensor.hallen_temperature
              - entity: alarm_control_panel.dammtorps_alle_lgh_alarm
                offStates:
                  - unarmed
              - entity: switch.hallen
              - entity: binary_sensor.entredorr
                offIcon: 'mdi:door'
            popup:
              scenesInARow: 2
              settings:
                closeButton: stäng
              switchHeight: 300px
              switchWidth: 110px
            title: Hallen
      - column: 2
        entities:
          - entities:
              - entity: light.malvinas_fonster
                icon: 'mdi:lamp'
              - entity: switch.malvinas_sang
                icon: 'mdi:light-switch'
              - entity: switch.malvinas_rum
                icon: 'mdi:floor-lamp'
                name: Malvinas Golvlampa
            popup:
              actionsInARow: 2
              settings:
                closeButton: stäng
              switchHeight: 300px
              switchWidth: 110px
            title: Malvinas rum
      - column: 2
        entities:
          - entities:
              - entity: light.evelins_fonster
                icon: 'mdi:lamp'
                offStates:
                  - 'off'
                  - unavailable
              - entity: switch.evelins_rum
                name: Evelins Golvlampa
              - card: weather-forecast
                noPadding: true
                wider: true
                cardOptions:
                  entity: weather.smhi_hemma
                cardStyle: |
                  ha-card {
                      padding: 5px!important;
                      display: flex!important;
                      flex-direction: column!important;
                      background: transparent!important;
                      box-shadow: none!important;
                      border-radius:0!important;
                  .content {
                      flex-direction: row!important;
                  .icon-image {
                      min-width: auto!important;
                  .icon-image > * {
                      height: 32px!important;
                      flex: 0 0 32px!important;
                  .info .name-state {
                      font-weight: 500;
                  .info .name-state .state {
                      font-size:14px!important;
                      text-align:right;
                  .info .name-state .name {
                  .info .temp-attribute {
                      width:100%;
                      font-weight: 500;
                  .info .temp-attribute .temp {
                          font-size: 16px!important;
                  .info .temp-attribute .temp span {
                          font-size: 14px!important;
                  .forecast {
                      font-size: 10px!important;
                      padding-top: 5px!important;
                  .forecast-image-icon {
                      padding:0!important;
                  .forecast-image-icon > * {
                      width:20px!important;
                      height:20px!important;
                      margin: 0 auto!important;
                  .forecast .temp {
                      margin-top:0!important;
                      font-size:12px!important;
                  .forecast .templow {
                      display:none;
            popup:
              actionsInARow: 2
              settings:
                closeButton: stäng
              switchHeight: 300px
              switchWidth: 110px
            title: Evelins rum
      - column: 2
        entities:
          - entities:
              - entity: switch.utomhus_vagg
                icon: 'mdi:wall-sconce'
                offStates:
                  - 'off'
                  - unavailable
              - entity: light.utomhus_ljusslinga
              - entity: light.busklampor
            popup:
              actionsInARow: 2
              settings:
                closeButton: stäng
              switchHeight: 300px
              switchWidth: 110px
            title: Utomhus
    row: 2
  - columns:
      - column: 1
        entities:
          - entities:
              - entity: switch.vardagsrum_hoger
              - entity: switch.sovrum_vanster
              - entity: switch.sovrum_hoger
              - entity: switch.sovrumssang_vanster
              - entity: switch.sovrumssang_hoger
              - entity: switch.sovrumsfonster_lampa
                  action: navigate
                  action: navigate
            popup:
              scenesInARow: 2
              settings:
                closeButton: stäng
              switchHeight: 300px
              switchWidth: 110px
            title: Knappar
        tileOnRow: 10
    row: 3
statePositionTop: false
style: |
  :host {
    --tile-background: rgba(10, 10, 10, 0.22);
    --tile-border-radius: 12px;
    --tile-width: 100px;
    --tile-height: 100px;
    --tile-on-background: var(--card-background-color);
    --tile-name-text-color: rgba(183, 183, 183, 0.59);
    --tile-on-name-text-color: var(--primary-text-color);
    --tile-state-text-color: rgba(183, 183, 183, 0.59);
    --tile-on-state-text-color: var(--paper-item-icon-active-color);
    --tile-state-changed-text-color: var(--primary-text-color);
    --tile-unavailable-state-text-color: rgba(255, 0, 0, 1);
    --tile-value-text-color: var(--primary-text-color);
    --tile-icon-color: rgba(183, 183, 183, 0.59);
    --tile-on-icon-color: var(--paper-item-icon-active-color);
    --tile-width-mobile: 90px;
    --tile-height-mobile: 90px;
    --tile-icon-size: 30px;
    --tile-padding-top: 0
titleColor: '#FFF'
type: 'custom:homekit-card'
useBrightness: true
useTemperature: false
Really stange i never had problems…
Any thing in the developer tools console of the browser?
Mmm, I can’t find this in HACS, how is it exactly called there?
OK, I better properly read the github :slight_smile: sorry
Thanks for this, when I try to input it as you have put it above, it doesnt like the location of the first } and tells me there is an indention issue? If I allign them nothing happens to the card?
Strange, can you share tour config maybe i can find what is going on.
IF i klick home they apear or if i wait.
