Custom Lovelace Card - Homekit style card
I am running the latest version of Home Assistant (0.105.3) and the latest version of all your cards.
Here is my global config:
climate.bedroom_ac:
    card:
      entity: climate.bedroom_ac
      type: 'custom:thermostat-popup-card'
    style:
      '--iron-icon-fill-color': '#FFF'
      align-items: center
      background: 'rgba(0, 0, 0, 0.8)'
      display: block
      flex-direction: column
      height: 100%
      justify-content: center
      left: 0
      margin: 0
      position: fixed
      top: 0
      width: 100%
      z-index: 999
    title: ''
and here is my card config:
- entity: climate.bedroom_ac
   tap_action:
     action: more-info
  wider: true
Turns out there was setting in the theme I was using that was making the background of the header of the card darker and I just had to change more-info-header-background to transparent and now the popup card is all 1 color. This is actually a bit confusing since the normal default more-info popup card uses secondary-background-color.
@DBuit thank you for fixing the fullscreen issues some of us had on all your cards! Saves me editing the files every time an update comes. I do have a question though. I tried to use the preset scenes, and though it works nicely, the size is huge! Would it be possible to change the size of the scenes/preset buttons to something more like this?
That is the only thing I really miss. I love the more info button, though I believe it would be better if it is on the top right so that regardless of screensize the button would always be at the same spot. I think that probably the full screen option was meant to fix that, but whenever I use full-screen it would do those crazy -64px margins and the cards would be unreadable on a mobile phone (they work fine on a desktop btw).
my thoughts exactly, as suggested here: Custom Lovelace Card - Homekit style card - #372 by Mariusthvdb
hope @DBuit will reconsider ā€¦
Hi @jimz011,
can you share exactly what style changes you did for the action buttons i can see what i can do.
Maybe make it configurable or change it.
and @Mariusthvdb i got it on my list of thing to do to make the position of the button configurable :slight_smile:
Something wierd is happening with thermostat popup cardā€¦
When climate is off, popup card is blank, but when I switch climate on, popup shows up normalyā€¦
      - type: custom:homekit-card
        home: false
        title:
        statePositionTop: true
        tileHoldAnimation: true
        useBrightness: true
        useTemperature: false
        entities:
              - entity: climate.centralno
                wider: false
                tap_action:
                  action: toggle
                  entity: input_boolean.automode_centralno
                popup:
                  type: custom:thermostat-popup-card
Anything I need to add here?
Good observation @INTEL
@DBuit I also have the same problem. I hadnā€™t noticed it when I reported my blank screen problem yesterday but tried now when @INTEL reported it and itā€™s the same for me
@INTEL @mkhattab that is strange Will check if out and fix it
I wish it were style changes so I could easily share it with you. Actually the card you see in the screenshot is the rgb-card which has these small rounded circles by default. I had wished to use your scene selector instead so I can use the settings button you have made (but unfortunately the location of the settings button doesnā€™t look very nice when not running fullscreen) but I mentioned that already.
Though when I use your scenes, the buttons are huge, but I mean immens! On a desktop or ipad this is probably not as apparent, but on an iPhone X they are almost as big as my standard buttons in lovelace.
Hi everyone,
Small update for light pop-up added actionSize (@jimz011) and settingsPosition (@jimz011 and @Mariusthvdb) as configuration.
You can check here how to use it: https://github.com/DBuit/light-popup-card/releases/tag/0.4.3
Might also add extra size settings for mobile seperate from global because they become pretty small on large screens :thinking:
The other popup cards will follow soon.
Will test this tonight, thank you once again!
I get an error in mij log:
/community_plugin/homekit-panel-card/homekit-panel-card.js:186:382 SyntaxError: invalid regular expression flag s
Iā€™m running Home Assistant Core and have installed the card with HASC, what can cause this?
Hi @Cadster,
I got no problems with the card and nobody mentioned so i think it is in your config.
Can you share yours?
Hello everyone,
I just updated thermostat, cover and media_player popup. @jimz011
  • Added settingsPosition for all 3
  • Added actionSize for cover and media_player
  • Fixed thermostat invisible when off @mkhattab and @INTEL
I also updated light popup with a fix for the settingsPosition when in fullscreen.
Hi @DBuit is there something we should change in the config?
I still have the same problem after updating to the latest thermostat-popup (0.2.2)
That is strange, any errors in console?
None at all.
I am investigating but itā€™s strange because it was working fine until the last update which broke something and I have not changed my config (which I posted above when reporting the error) since then
@mkhattab U use HACS? try installing older version 0.2 and does it work than?
Yes I use HACS. I tried downgrading thermostat popup a couple of versions 0.2.1, 0.2 and even 0.1.1 and still the same result.
Here is my current config once again just to be sure Iā€™m not doing anything wrong
popup_cards:
  climate.bedroom_ac:
    card:
    style:
      align-items: center
      display: block
      height: 100%
      left: 0
      margin: 0
      position: fixed
      top: 0
      width: 100%
      z-index: 999
    title: ''
and
  tap_action:
    action: more-info
  wider: true
Not really seeing something that is wrong.
I got this and works for me
climate.climatedemo:
    title: ""
    style:
      position: fixed
      z-index: 999
      top: 0
      left: 0
      height: 100%
      width: 100%
      display: block
      align-items: center
      background: rgba(0, 0, 0, 0.8)
      margin: 0
      "--iron-icon-fill-color": "#FFF"
    card:
      settingsPosition: top
      entity: climate.climatedemo
      settings: true
- entity: climate.climatedemo
  tap_action:
     action: more-info
