Hi @DBuit
Is it possible to get the action buttion into the switch-popup-card?
I tried this, no luck
hold_action:
action: call-service
service: browser_mod.popup
service_data:
title: '[[[ return entity.attributes.friendly_name ]]]'
deviceID: this
card:
type: entities
entities:
- type: custom:switch-popup-card
entity: '[[[ return entity.entity_id ]]]'
icon: none
fullscreen: false
brightnessWidth: 120px
brightnessHeight: 240px
borderRadius: 1.7em
sliderColor: '#c7c7c7'
sliderTrackColor: rgba(25, 25, 25, 0.9)
noActiveState: '-'
entity_value_path: attributes.brightness
service: light.turn_on
service_data:
entity_id: this
brightness: value
entities:
- '[[[ return entity.entity_id ]]]'
buttons:
- icon: "mdi:lightbulb-on"
value: 255
color: "#FFF"
icon_color: "rgba(255,255,255,1)"
value: 192
color: "#FFF"
icon_color: "rgba(255,255,255,0.8)"
value: 128
color: "#FFF"
icon_color: "rgba(255,255,255,0.6)"
value: 64
color: "#FFF"
icon_color: "rgba(255,255,255,0.4)"
actionSize: 4.5em
actionsInARow: 2
actions:
- service: light.turn_on
service_data:
entity_id: '[[[ return entity.entity_id ]]]'
color_temp: 447
brightness: 145
color: "#FDCA64"
service_data:
color_temp: 346
brightness: 255
color: "#FFFF83"
service_data:
color_temp: 367
brightness: 77
color: "#cc8800"
- service: browser_mod.popup
service_data:
deviceID: this
card:
type: entities
show_header_toggle: false
entities:
- entity: '[[[ return entity.entity_id ]]]'
secondary_info: last-changed
- type: custom:light-entity-card
brightness: false
color_temp: true
full_width_sliders: true
hide_header: true
show_slider_percent: true
smooth_color_wheel: true
consolidate_entities: true
DBuit
(DBuit)
January 7, 2021, 12:10pm
1302
No switch card has no actions
Ok, would that be something to integrate?
Cool, just gave the open issue a +1 on Github.
Also made a feature request for the image on action buttion icons I mentioned in the other tread
royle
(roy)
January 7, 2021, 12:59pm
1306
I having some problems adding calendar card to my tablet dashboard.
When I am using the widerSize and higherSize
the other tile that I am adding are to small and a there is a gap I canât fill with tiles.
Any suggestions ?
DBuit
(DBuit)
January 7, 2021, 3:30pm
1307
set masonry
to true. This will make it possible for smaller tiles to fill the gapes.
The website works great on mobile, the HomeKit panel syle looks amazing. And scrolling works fine. But Iâm not able to scroll in the home assistant app. Am I doing something wrong?
andrew47
(Andrew)
January 7, 2021, 4:42pm
1309
Set home to false and the tiles start at the top
Well to put it in a easy as i can.
If one could use a entities card funktion on that extra status option that would make us able to have a washer switch as main and as status you use a Enteties card funktion as the status so that the time get to be shown the right way so to speak.
So that this button as showned below.
Will become this like this button in the picture below. or something like it.
The way i did it in the picture is shorten down hour to h, And in this cause Minuts could be m and Second s. That propably would make other statuses in the process look better.
This way you can get other status you cant right now. In my example the washing time when its done or when it was completed.
But now i was just free basing. of what i think would be the ideal case. I know your a new dad so i being a dad myself i get if this dont get a high priorety. But one could always wish for a late christmas present
kaosmagix
(Cristian Van Loenen)
January 9, 2021, 10:32am
1311
This card is great and made it very easy to create a nice usable mobile UI.
I would like to add the Volume level of a media player as the additional state shown (top right circle) using the state and statePath setting. This works but it shows the value unrounded and with all digits. The volume_level ranges between 0-1 and I would like to show it in the circle as a percentage (so 40% and not 0.400000000000023) and if possible also showing the circle fill like brightness does for example. Is it possible to add functionality to add settings for rounding of the attribute, and the option to show it in the circle like for example Brightness does?
# lovelace_gen
entity: {{ media_player_entity }}
state: {{ media_player_entity }}
statePath: attributes.volume_level
e1miran
January 10, 2021, 4:25pm
1312
Is the âuserâ variable implemented in JS templating? I canât get it to work. Maybe my code is incorrect? The if statement always resolves false no matter the user.
hide: |
if (user == "Anthony")
return true;
else
return false;
I love this option but it slightly uneven as seen in the screenshot. Any ideas how to fix this?
maxym
January 12, 2021, 12:19am
1314
Hello
No one is using popup card defined for multiple entities at once together with settingsCard?
How do you access more light attributes with HK style GUI?
e1miran
January 12, 2021, 7:14am
1315
Figured it out. Should be user.name.
Just wanted to share if someone allse has problems with Enteties time line the code ive found and gotten to work to get the right sensor showing the right time for my washer.
sensors:
washer_status_iso:
friendly_name: "Status"
value_template: >-
{% if is_state('sensor.tvattmaskin_washer_job_state', 'none') %}
AvstÀngd
{% elif is_state('sensor.tvattmaskin_washer_machine_state', 'pause') %}
VĂ€ntar
{% elif is_state('sensor.tvattmaskin_washer_machine_state', 'stop') %}
Stoppad
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'airWash') %}
LuftSköljer
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'cooling') %}
Kyler
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'delayWash') %}
FörlÀngdtvÀtt
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'drying') %}
Torkar
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'finish') %}
FĂ€rdig
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'preWash') %}
FörtvÀtt
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'rinse') %}
Sköljer
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'spin') %}
Snurra
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'wash') %}
TvÀttar
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'weightSensing') %}
Viktsensor
{% elif is_state('sensor.tvattmaskin_washer_job_state', 'wrinklePrevent') %}
Vikelskyddar
{% endif %}
### Template sensor for Maq Lavar state, depending on SmartThings auto-generated sensors ###
state_maq_lavar_new:
friendly_name: "TvÀttmaskin"
value_template: >-
{%- if states('switch.tvattmaskin')|lower == "off" -%}
Off
{%- elif states('switch.tvattmaskin')|lower == "on" -%}
{%- if states('sensor.tvattmaskin_washer_machine_state')|lower != "run" -%}
{{ states('sensor.tvattmaskin_washer_machine_state')|capitalize }}
{%- else -%}
{{ states('sensor.tvattmaskin_washer_job_state')|capitalize }}
{%- endif -%}
{%- else -%}
Unavailable
{%- endif -%}
icon_template: "{{ 'mdi:washing-machine' }}"
### Template sensor for Maq Lavar remaining cycle Time, depending on SmartThings auto-generated sensors ###
maq_lavar_remaining:
friendly_name: "Remaining Time"
value_template: >-
{%- if states('switch.tvattmaskin')|lower == "on" and states('sensor.tvattmaskin_washer_machine_state')|lower != "stop" -%}
{%- if states('sensor.tvattmaskin_washer_job_state')|lower != "none" and states('sensor.tvattmaskin_washer_job_state')|lower != "finish" -%}
{%- if as_timestamp(states('sensor.tvattmaskin_washer_completion_time')) > utcnow().timestamp() -%}
{%- if states('sensor.tvattmaskin_washer_job_state')|lower == "delaywash" -%}
-{{ (( as_timestamp(states('sensor.tvattmaskin_washer_completion_time')) - utcnow().timestamp() ) + 60) | timestamp_custom ("%H:%M", false) }}
{%- else -%}
{%- endif -%}
{%- else -%}
Done
{%- endif -%}
{%- else -%}
Idle
{%- endif -%}
{%- elif states('switch.tvattmaskin')|lower == "off" -%}
Idle
{%- else -%}
Unavailable
{%- endif -%}
Hi m8 here what i use on my washer to get the time right. Maby you can modefy it to get it working for you.
value_template: >-
{%- else -%}
{%- endif -%}
{%- else -%}
Done
{%- endif -%}
{%- else -%}
Idle
{%- endif -%}
Idle
{%- else -%}
Unavailable
{%- endif -%}
LAndre
(LAndre)
January 12, 2021, 9:16pm
1318
Hi guys!
Firts, DBuit, great work, your card is amazing.
I have some issues with one card, I am using a weather card but I cant seem to be able to make a card transparent in no way. It shows the weather forecast card and white background (if I put color it has strange white border?)
Can somebody help?
I saw your youtube video with Weather icon on top, that would also be nice, how did you do it?
Many thanks!
U could use a diffrent theme for it.
Of you search weather in this thread u should find some examples how to theme it.
Hello, does anyone else have this problem? for a few weeks every time I enter the application I get this error, it stays for a few seconds(2-5) and then it displays everything ok.
