I would not tell you to try again if i did not think the answer was there. I have all the things u do But working as they should. And if you still can’t get it to work by using an example from the readme. Then its some other mod interfearing. So try disable them one by one. Best of luck
Hi @jimz011 ,
thanks a lot for creating the fork for this. Finally having icons back is great.
I am however missing the icon for the auto mode of my Tado thermostats.
Heating and off modes are represented fine, but the auto mode icon isn’t showing (see image below for example of it in the simple thermostat card). Any way you could add this?
Funny thing is that I am not a developer, so I was actually very surprised that what I changed even worked. I will try to make that icon work again, but I can’t guarantee it (since well, I’m not a developer ).
But I’ll try, just keep an eye on HACS for an update
I have the popup-card working in the browser for both the light-popup-card and switch-popup-card. It works exactly how I want it. My problem though is that it is not working on the companion app (android). If I use my phone to open a web browser to HA the popup works but it does nothing in the app. I can post code if needed. I’m thinking it has something to do with the browser-mod utility. I installed it through HACS. Also, service: browser_mod:debug does nothing.
-Edit: Clearing data for the companion app resolved my issue.
I used the switch-popup-card to make a popup menu that turns on my TV/AVR/Devices and sets everything to the correct input. Maybe someone else would like this for inspiration.
The entity_value_path: attributes.percentage field isn’t used, but it doesn’t work without it. Also, I’m using the simple-icons addon to get the branded icons (xbox, nvidia, switch, etc).
Hope someone finds this useful.
the settings button dont works for me, because my led stripe has until i switch it on, no color rgb wheel. and when i use the entity for settings he oonly shows me a switch unter the settings button.
For this use a light-entity card as the settings page card. And then set it up to show all available features regardless if the entity is on/off. Its probably the neatest way.
I removed the swipe card because it didnt work very well for me.
