I am running Hass.io on Rpi 3. I modified a custom media_player component adding a new function ‘set_channel’ in webostv.py. I also defined in
media_player/init.py
in class
MediaPlayerDevice
and the two methods:
def set_channel(self, channel):
"""Set the TV channel ."""
raise NotImplementedError()
def async_set_channel(self, channel):
"""Set the TV channel 'channel'.
This method must be run in the event loop and returns a coroutine.
return self.hass.async_add_job(self.set_channel, channel)
At run time, calling the service set_chanell I get en error al this line:
yield from getattr(player, method['method'])(**params)
HA is saying that no method ’ async_set_channel’ exists despite the above-mentioned definition.
Can some python/home assistant expert help me, please? I would like to be able to set the channel with name on my LGWebOs Tv.
Thank you very much!
Best regards,
Noro
