After HA reset yesterday my custom modbus integration stopped working.
When checking the YML configuration it shows error: Integration error: modbus - Requirements for modbus not found: [‘pymodbus==3.1.3’].
This worked without a problem for past few months, what might’ve changed?
Hey Peter,
The HA OS V9.5 is installed on a Virtual machine on a server - which I had to restart yesterday. The server came back online along with HA, but from this point the custom modbus integration stopped working.
I have not changed anything in the HA itself before the error occured.
Looking at logs I can see some more errors regarding to modbus:
Unable to install package pymodbus==3.1.3: WARNING: Ignoring invalid distribution -ymodbus (/usr/local/lib/python3.10/site-packages) WARNING: Ignoring invalid distribution -ymodbus (/usr/local/lib/python3.10/site-packages) ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: '/usr/local/lib/python3.10/site-packages/pymodbus-3.1.3.dist-info/METADATA' WARNING: Ignoring invalid distribution -ymodbus (/usr/local/lib/python3.10/site-packages) WARNING: Ignoring invalid distribution -ymodbus (/usr/local/lib/python3.10/site-packages) WARNING: Ignoring invalid distribution -ymodbus (/usr/local/lib/python3.10/site-packages) [notice] A new release of pip is available: 23.0 -> 23.0.1 [notice] To update, run: pip install --upgrade pip
Looking online I can see that this might be cause by python itself incorrectly adding ~ prefix to the modbus library.
Editing:
Logged in to the VM shell and then to the homeassistant docker container using
docker exec -it homeassistant /bin/bash
Located the site-packages directory where indeed ymodbus packages had ~ prexif. Removed the packages and restarted HA.
Now the error is:
Unable to install package pymodbus==3.1.3: ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: '/usr/local/lib/python3.10/site-packages/pymodbus-3.1.3.dist-info/METADATA' [notice] A new release of pip is available: 23.0 -> 23.0.1 [notice] To update, run: pip install --upgrade pip
Checked the contents of this directory and sure enough, inside there’s only some .tmp file.
Last edit:
removed the pymodbus3.1.1 library folder, run the “ha supervisor repair” command, restarted VM and modbus is working.
Not sure what happened that broke it
