Is it possible to copy/modify the Motion Lights blueprint to capture the state of the light being turned on?
My objective, so this doesn’t turn into an X-Y-Z problem, is I’m trying to tie in my my exterior lights to my reolink cameras. I want to turn on my exterior lights for 2 minutes.
If the lights were previously on, I want to them to stay on.
If they were were previously off, I want them to turn off.
if they were set to 50%, I want them to return to 50%.
Using a blueprint is there a way to capture the state once, and not overwrite it if the event recurs within 2 minutes. (If it overwrote those setting while its running I would just assume it would permanently be on, because if we are capturing it while its on it would just return to on.)
I also want to add a condition, to only run between sunset and sunrise, but I think that is easy enough.
Anyone have any suggestions.
