Hi there!
I want to create my mqtt component. I’m trying to compile the code from the example, but the compilation only happens when I remove the ability to work with json. Otherwise an error. What am I doing wrong ?
test.h
#include "esphome.h"
class MyCustomComponent : public Component, public CustomMQTTDevice {
public:
void setup() override {
// This will be called once to set up the component
// think of it as the setup() call in Arduino
pinMode(6, OUTPUT);
subscribe("the/topic", &MyCustomComponent::on_message);
// also supports JSON messages
subscribe_json("the/json/topic", &MyCustomComponent::on_json_message);
void on_message(const std::string &payload) {
if (payload == "ON") {
digitalWrite(6, HIGH);
publish("the/other/topic", "Hello World!");
} else {
digitalWrite(6, LOW);
publish("the/other/topic", 42);
void on_json_message(JsonObject &root) {
if (!root.containsKey("key"))
return;
int value = root["key"];
// do something with Json Object
// publish JSON using lambda syntax
publish_json("the/other/json/topic", [=](JsonObject &root2) {
root2["key"] = "Hello World";
test.yaml
esphome:
includes:
- test.h
esp8266:
board: nodemcuv2
mqtt:
topic_prefix: test
discovery: false
broker: ххх
port: ****
username: ****
password: !secret mqtt_password
discovery_prefix: homeassistant
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret api_password
ota:
password: !secret ota_password
web_server:
port: 8080
auth:
username: !secret web_user
password: !secret web_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-433MHz Fallback Hotspot"
password: !secret fail_password
captive_portal:
custom_component:
- lambda: |-
auto my = new MyCustomComponent();
return {my};
log
INFO Reading configuration /config/esphome/test.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing test (board: nodemcuv2; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://недопустимая ссылка/configure-pio-ldf
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|-- <ESPAsyncWebServer-esphome> 2.1.0
| |-- <Hash> 1.0
| |-- <ESP8266WiFi> 1.0
|-- <DNSServer> 1.1.1
|-- <ESP8266mDNS> 1.2
|-- <AsyncMqttClient-esphome> 0.8.6
|-- <ArduinoJson> 6.18.5
Compiling /data/test/.pioenvs/test/src/main.cpp.o
In file included from src/main.cpp:28:
src/test.h: In member function 'virtual void MyCustomComponent::setup()':
src/test.h:13:73: error: no matching function for call to 'MyCustomComponent::subscribe_json(const char [15], void (MyCustomComponent::*)(ArduinoJson::JsonObject&))'
13 | subscribe_json("the/json/topic", &MyCustomComponent::on_json_message);
In file included from src/esphome.h:25,
from src/main.cpp:3:
src/esphome/components/mqtt/custom_mqtt_device.h:96:8: note: candidate: 'template<class T> void esphome::mqtt::CustomMQTTDevice::subscribe_json(const string&, void (T::*)(const string&, ArduinoJson::JsonObject), uint8_t)'
96 | void subscribe_json(const std::string &topic, void (T::*callback)(const std::string &, JsonObject), uint8_t qos = 0);
src/esphome/components/mqtt/custom_mqtt_device.h:96:8: note: template argument deduction/substitution failed:
src/test.h:13:73: note: types 'const string' {aka 'const std::__cxx11::basic_string<char>'} and 'ArduinoJson::JsonObject' {aka 'ArduinoJson6185_D1::ObjectRef'} have incompatible cv-qualifiers
src/esphome/components/mqtt/custom_mqtt_device.h:98:29: note: candidate: 'template<class T> void esphome::mqtt::CustomMQTTDevice::subscribe_json(const string&, void (T::*)(ArduinoJson::JsonObject), uint8_t)'
98 | template<typename T> void subscribe_json(const std::string &topic, void (T::*callback)(JsonObject), uint8_t qos = 0);
src/esphome/components/mqtt/custom_mqtt_device.h:98:29: note: template argument deduction/substitution failed:
src/test.h:13:73: note: mismatched types 'ArduinoJson::JsonObject' {aka 'ArduinoJson6185_D1::ObjectRef'} and 'ArduinoJson::JsonObject&' {aka 'ArduinoJson6185_D1::ObjectRef&'}
src/test.h: In member function 'void MyCustomComponent::on_json_message(ArduinoJson::JsonObject&)':
src/test.h:34:6: error: no matching function for call to 'MyCustomComponent::publish_json(const char [21], MyCustomComponent::on_json_message(ArduinoJson::JsonObject&)::<lambda(ArduinoJson::JsonObject&)>)'
34 | });
src/esphome/components/mqtt/custom_mqtt_device.h:167:8: note: candidate: 'bool esphome::mqtt::CustomMQTTDevice::publish_json(const string&, const json_build_t&, uint8_t, bool)'
167 | bool publish_json(const std::string &topic, const json::json_build_t &f, uint8_t qos, bool retain);
src/esphome/components/mqtt/custom_mqtt_device.h:167:8: note: candidate expects 4 arguments, 2 provided
src/esphome/components/mqtt/custom_mqtt_device.h:184:8: note: candidate: 'bool esphome::mqtt::CustomMQTTDevice::publish_json(const string&, const json_build_t&)'
184 | bool publish_json(const std::string &topic, const json::json_build_t &f);
src/esphome/components/mqtt/custom_mqtt_device.h:184:73: note: no known conversion for argument 2 from 'MyCustomComponent::on_json_message(ArduinoJson::JsonObject&)::<lambda(ArduinoJson::JsonObject&)>' to 'const json_build_t&' {aka 'const std::function<void(ArduinoJson6185_D1::ObjectRef)>&'}
*** [/data/test/.pioenvs/test/src/main.cpp.o] Error 1
========================== [FAILED] Took 7.52 seconds ==========================
