Following the docs for a mqtt light with no rgb support, I have the following:
- name: "R2D2 Holoprojector"
unique_id: "r2d2_df12b4032fe411e4800bcd1fd09bffdc"
state_topic: "r2d2/holo/state"
command_topic: "r2d2/holo/switch"
payload_on: "ON"
payload_off: "OFF"
brightness_state_topic: "r2d2/holo/brightness"
brightness_command_topic: "r2d2/holo/brightness/set"
on_command_type: "brightness"
optimistic: false
I can see in both my topics (state_topic
and brightness_state_topic
) that HA is receiving a valid int value of 0-255. I set up a sensor to confirm this as well. I can navigate to the STATES developer tool and play with the brightness slider, but when I add the light to a dashboard using the Light card, the brightness slider is immovable.
Am I not sending/reporting the brightness state correctly?
