Custom output Component with a tlc5947
I have been working at understanding how to add a custom component for controlling led strip sections with a 24 channel tlc5947 chip attached via SPI to an ESP32.
I feel like it should be quite easy as Adafruit has a library that could be used for communication.
Purley and simply I have not been able to get my head around adding such a thing even after reading the documentation many of times. Any help to get a better understanding would be very useful.
Anyone got an idea still not been able to create a working component for this.
I managed to get it working via an ESP8266 and one of those boards like the adafruit one. I had some trouble at first building ESPHome from my Raspberry Pi HA server but those were sorted as I upgraded to an RPi4. Here’s my ESPHome YAML (I may want to go the MQTT route but for now this works so here goes) :
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
# Optional manual IP
  manual_ip:
    static_ip: 192.168.1.66
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "tlc5947-unit1"
    password: "whatever" -------> insert yr own pwd here
# Example configuration entry
tlc5947:
  data_pin: GPIO12  #DIN  D6
  clock_pin: GPIO14 #CLK  D5
  lat_pin: GPIO15   #LAT  D8
# Individual outputs
output:
  - platform: tlc5947
    channel: 0
  - platform: tlc5947
    channel: 1
  - platform: tlc5947
    channel: 2
  - platform: tlc5947
    channel: 3
  - platform: tlc5947
    channel: 4
  - platform: tlc5947
    channel: 5
  - platform: tlc5947
    channel: 6
  - platform: tlc5947
    channel: 7
  - platform: tlc5947
    channel: 8
  - platform: tlc5947
    channel: 9
  - platform: tlc5947
    channel: 10
  - platform: tlc5947
    channel: 11
  - platform: tlc5947
    channel: 12
  - platform: tlc5947
    channel: 13
  - platform: tlc5947
    channel: 14
  - platform: tlc5947
    channel: 15
  - platform: tlc5947
    channel: 16
  - platform: tlc5947
    channel: 17
  - platform: tlc5947
    channel: 18
  - platform: tlc5947
    channel: 19
  - platform: tlc5947
    channel: 20
  - platform: tlc5947
    channel: 21
  - platform: tlc5947
    channel: 22
  - platform: tlc5947
    channel: 23
light:
  - platform: monochromatic
    output: output_00
    output: output_01
    output: output_02
    output: output_03
    output: output_04
    output: output_05
    output: output_06
    output: output_07
    output: output_08
    output: output_09
    output: output_10
    output: output_11
    output: output_12
    output: output_13
    output: output_14
    output: output_15
    output: output_16
    output: output_17
    output: output_18
    output: output_19
    output: output_20
    output: output_21
    output: output_22
    output: output_23
And then in ESPHome just configure the newly discovered unit. I added a separate entry in the sidebar, and then when you edit that dashboard and add a card just select the newly created entity, tick the ''SELECT ALL" box and all 24 buttons are added just like that :
When you click on a button you get to see the dimmer functionality of that LED.
I have tested both the direct LED connection to the TLC5947-breakout-board using the ESP to power the LED, as well as as the external power supply option running that from from 5V all the way to 24V. All works well I find 12V a fine balance for the luminosity of my Niko 6-button pushbuttons.
