Hi all!
I am having some issues with my config flow. I added a SelectSelector (dropdown) to select a script in further functionalities in the integration. This is optional however.
I am now facing the issue that if I don’t select any script, I get the following error:
I suspect this is because of some constraints in the SelectSelector class as I have made it an optional field. Is there any way to circumvent this? The code for the config_flow can be consulted here: ps3-home-assistant/custom_components/ps3/config_flow.py at 0ec9c641076a5c5a2cff480ebfc68c0ea39e6102 · SDR3078/ps3-home-assistant · GitHub.
Thanks!
