I have created a Python script that calculates the optimal color temperature for my lights based on the sun’s position and weather information. I want to run this script every 5 minutes and publish the color temperature values as a sensor in Home Assistant.
Initial Approach
I tried using the command_line integration to run the Python script at an interval of 300 seconds (5 minutes) to update a sensor with the calculated values. This approach is neat and straightforward—if it works.
The Issue
My script relies on custom Python packages. I logged into my HA VM (using the SSH Terminal add-on) and created a virtual environment (venv) where I installed the required packages. However, when I try to run the script using the command_line integration with the venv interpreter, it fails to find the interpreter.
Why?
The command executed by the command_line integration runs inside the Home Assistant container (running on the HAOS VM), and the paths to the interpreter are not the same as on my host. I could log into the container and create the venv there, but I would prefer not to do that.
Request for Suggestions
Does anyone have suggestions on how I can solve this issue? Alternatively, is there another way to achieve my goal—perhaps by running the script as an add-on or using another method?
High-level suggestion: Run the script in an easier environment where you have more control and publish the values using MQTT. I can’t help you with how to do that, but it should be very doable, and HA’s MQTT integration is easy to work with.
