Just installed and getting the following message:
“Expected a value type…”
Am I doing something wrong?
Thanks,
Thanks,
I am getting same error… did you solve this?
not yet, but I filed a feature request: Add secondary_info: last-triggered for entities-card
maybe that would be of use in this card also? If so, please bump the FR…
Has anyone managed to combine a template with a string in the then
or else
fields?
My code looks like this:
- entity: sensor.ha_installed_version
type: "custom:secondaryinfo-entity-row"
secondary_info: '[[ if({entity}.state == sensor.ha_available_version.state , "Up to date" , "New version available: [[ sensor.ha_available_version.state ]]") ]]'
Unfortunately, this results in a “Template matching failed” error.
I can replace "New version available: [[ sensor.ha_available_version.state ]]"
with either "New version available: "
or just sensor.ha_available_version.state
, both of which work. But I cannot seem to figure out how to concatenate the two.
@kikon_kike You were trying to achieve the exact same thing as me. Did you ever work it out?
@iptvcld It seems you were trying something similar. Have you had any luck?
I think it would probably be simpler (easier?) to create a ‘regular’ template sensor with the if
statements, and then add that sensor to secondary_info rather than trying to do it all in secondary_info.
For some reason, I’m getting the same error here, it worked perfectly fine a few days ago…
Could you share the template that was working for you?
Is it possible to fix that issue https://github.com/custom-cards/secondaryinfo-entity-row/issues/20 ?
Here is my example that doesn’t work
card:
show_header_toggle: false
title: Rachunki
type: entities
filter:
include:
- entity_id: variable.*
options:
secondary_info: >-
Do zapłaty: <b style='color:[[ if({entity}.attributes.czy_oplacony ==
'nie', 'green', 'red') ]]'>[[ {entity}.attributes.do_zaplaty ]]</b>
type: 'custom:secondaryinfo-entity-row'
sort:
method: state
type: 'custom:auto-entities'
Hi all,
I updated Home assistant to 106.5 and now all my entities that where using secondaryinfo-entity-row are not working and display this message:
Old version of card-tools found. Get the latest version of card-tools.js from https://github.com/thomasloven/lovelace-card-tools
I installed the custom components using HACS.
The problem is related to the fact that the developer need to fix this custom components or do I have to change somenthing?
Install card-tools 2.1.1 manually and change the ressource in Lovelace.
I don’t know why this version is not installable with HACS.
Thanks for the help!
I solved manually installing card-tools as you suggested.
However after the install I had to delete the cache in the browser and secondaryinfo-entity-row started to work again.
is there any way to format the time stamp?
this is not working for me:
[[ {entity}.attributes.next_dawn | timestamp_custom('%D %-I:%M %P') ]]
Is it possible to do simple calculations on state or attribute values? (e.g. subtract a static amount of time from a date)
You need to convert it to a timestamp first.
{{ as_timestamp(states.sun.sun.attributes.next_dawn) | timestamp_custom('%D %-I:%M %P') }}
works in the template editor.
I tried your suggestion, but this it’s not working for me:
secondary_info: "Last Update: [[ {{ as_timestamp(states.sensor.MYSENSORID.attributes.time) | timestamp_custom('%D %-I:%M %P') }} ]]"
However
is working well in the template page under developer tools.
I reed here that secondary info don’t support jinja. So I think that’s the problem.
Is anyone using this with popup cards?
If I click on the state I get the popup I’ve defined but if I click on the name I get the more-info card.
eg
Clicking on the ‘8.0’ gives me my popup:
Clicking on ‘Number of zones defined’ gives me more-info:
type: custom:multiple-entity-row
entity: input_number.irrigation_number_of_zones
name: Number of zones defined
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: Number of zones defined
card:
type: entities
entities:
- entity: input_number.irrigation_number_of_zones
deviceID:
- this
style:
font-family: Oswald
font-size: 14px
box-shadow: 0em 0em 0.5em
opacity: 0.9
Would it be possible to add support for the new lovelace Grid option? thanks
can you share a link to that “new” grid option please?
