I have one more problem. I have 2 cars and with restarting home assistant sometimes on of the 2 cars fills with the initialization.
2020-05-15 18:02:58 WARNING (MainThread) [custom_components.rdw] Unable to update data from endpoint m9d7-ebf2 for XXXXXX: HTTPSConnectionPool(host=‘opendata.rdw.nl’, port=443): Max retries exceeded with url: /resource/m9d7-ebf2.json?kenteken=ZP051X (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0x7fc0f01b8e50>: Failed to establish a new connection: [Errno -2] Name does not resolve’))
2020-05-15 18:02:58 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Auto Giel (configuration.yaml) for rdw
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 216, in async_setup
hass, self
File “/config/custom_components/rdw/init.py”, line 106, in async_setup_entry
raise PlatformNotReady
homeassistant.exceptions.PlatformNotReady
2020-05-15 18:03:00 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.rdw
Its not a problem that it fails, but once it failed it will not retry to re-initialize the sensors. I have to restart home assistant again to make it work.
[edit]
hmmz restarting will not fix this. Do you know what this error means?
This means that Home Assistant can’t resolve the hostname opendata.rdw.nl. Your DNS server isn’t working and/or reachable. This is not a specific RDW-component problem, and you’ll probably see have this problem with other Cloud-components in Home Assistant as well.
That should not happen. The RDW component should re-initialize the sensors automatically like any other component in HA when the internet connection is up again/when the DNS server is up again.
Source: custom_components/rdw/init.py:275
First occurred: 19:31:29 (2 occurrences)
Last logged: 19:31:29
Error setting up entry C1 (configuration.yaml) for rdw
Error setting up entry BMW (configuration.yaml) for rdw
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 217, in async_setup
hass, self
File “/config/custom_components/rdw/init.py”, line 107, in async_setup_entry
if not await rdw.async_update():
File “/config/custom_components/rdw/init.py”, line 275, in async_update
raise RDWEntity.NotRegistered
custom_components.rdw.RDWEntity.NotRegistered
Looks like the license plate ID isn’t correct. Please check that you’ve entered the correct license plate ID.
Unrelated to your specific problem: looks like the error handling for unregistered license plates isn’t that user friendly. I’ll look into that and try and fix it in a future release.
tried to add some plates using the GUI, but i’ll get this error:
already tried to : delete the old setting from the config.yaml , removed everything that’s RDW, reboot the HAS installation several times
the log tells me File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 256, in _async_handle_step result: FlowResult = await getattr(flow, method)(user_input) File "/config/custom_components/rdw/config_flow.py", line 101, in async_step_user config_entry = {'data', user_input} TypeError: unhashable type: 'dict'
As it is fairly static: can’t you just add it to the card title or use a markdown card?
Although it could be useful for Automations perhaps to have a sensor (or sensor attribute) that holds the licenseplate as value.
there seems to be oneother issue with this integration. Getting the error that the date isn’t okay. and the log file tells me :
Blockquote Error handling request
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py”, line 433, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py”, line 504, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 85, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 80, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 236, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 148, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 181, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 271, in async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 367, in _async_handle_step
File “/config/custom_components/rdw/config_flow.py”, line 101, in async_step_user
config_entry = {‘data’, user_input}
TypeError: unhashable type: ‘dict’
