Custom sensor for dutch license plate checks (APK check)
I have setup rdw but it don’t work.
My conf:
rdw:
  • plate: 0xxx00
    binary_sensors:
    • insured
      sensors:
    • expdate
    • recall
  • plate: 00xxxx
    binary_sensors:
    • insured
      sensors:
    • expdate
    • recall
Error:
Logboekdetails (ERROR)
Logger: homeassistant.config_entries
Source: custom_components/rdw/init.py:275
First occurred: 19:31:29 (2 occurrences)
Last logged: 19:31:29
Error setting up entry C1 (configuration.yaml) for rdw
Error setting up entry BMW (configuration.yaml) for rdw
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 217, in async_setup
hass, self
File “/config/custom_components/rdw/init.py”, line 107, in async_setup_entry
if not await rdw.async_update():
File “/config/custom_components/rdw/init.py”, line 275, in async_update
raise RDWEntity.NotRegistered
custom_components.rdw.RDWEntity.NotRegistered
There is an error in line 16 of nl.json.
It says:
“name”: “name of the car”,
but this should be:
The comma is not right there.
Looks like the license plate ID isn’t correct. Please check that you’ve entered the correct license plate ID.
Unrelated to your specific problem: looks like the error handling for unregistered license plates isn’t that user friendly. I’ll look into that and try and fix it in a future release.
Thank you for pointing that out. It should be fixed in v2.9.8.
I used lowercase letters, that was wrong. Now adjusted to uppercase and it works.
tried to add some plates using the GUI, but i’ll get this error:
already tried to : delete the old setting from the config.yaml , removed everything that’s RDW, reboot the HAS installation several times
the log tells me
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 256, in _async_handle_step result: FlowResult = await getattr(flow, method)(user_input) File "/config/custom_components/rdw/config_flow.py", line 101, in async_step_user config_entry = {'data', user_input} TypeError: unhashable type: 'dict'
RDW has been build into HA version: 2021.12
Beta release notes: Home Assistant
(THANKS Frenck!!)
what can be the problem, the error still exists
@frenck WOW! thanks for integrating the component into the official Home Assistant repo! Mucho kudos!
How do you show the plate in Lovelace when added via the integration? There is no sensor for that
As it is fairly static: can’t you just add it to the card title or use a markdown card?
Although it could be useful for Automations perhaps to have a sensor (or sensor attribute) that holds the licenseplate as value.
Exactly. As it is not stored now, although I can’t find it, I can’t make an automation notification with the license plate as a value.
Perhaps you could open a topic on the featurerequests board here? I’d support your request :wink:
:wink:
I gave it my up vote, as promised!
Same here…did you find a solution?
there seems to be oneother issue with this integration. Getting the error that the date isn’t okay. and the log file tells me :
Blockquote Error handling request
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py”, line 433, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py”, line 504, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 85, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 80, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 236, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 148, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 181, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 271, in async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 367, in _async_handle_step
File “/config/custom_components/rdw/config_flow.py”, line 101, in async_step_user
config_entry = {‘data’, user_input}
TypeError: unhashable type: ‘dict’
Someone who can help me ?
