I got some plugs for my washing machine and dryer. I wanted to create a custom sensor
with a template now to watch the state of the wasching machine. But sadly sometimes the washing machine power draw jumps to 0W so I can’t just ask if its smaller than 3 as example then its not running anymore. I may have to do it if its longer than 2 minutes at 0W it is finished.
But I have no idea ho to do that with value templates?
Can anyone help me with that?
Use a statistics sensor to even out the power consumption over a few minutes that way when the statistics sensor say 0 then it is off, but that will happen with a delay of the same time as your statistics sensor is looking at.
I use the following:
- alias: Laundry Set Washer Status
- platform: numeric_state
entity_id: sensor.washer_plug_power
below: 1
for:
minutes: 5
above: 1
for:
minutes: 2
condition:
- "{{ trigger.from_state.state not in ['unknown', 'unavailable'] }}"
- service: input_boolean.turn_{{ 'on' if trigger.id == 'on' else 'off' }}
entity_id: input_boolean.laundry_washer_status
- alias: Laundry TTS Washer is Done
- platform: state
to: 'off'
condition:
- condition: time
after: '09:00:00'
before: '23:00:00'
- condition: or
conditions:
- condition: state
entity_id: person.spouse
state: 'home'
- condition: state
entity_id: person.me
state: 'home'
- service: notify.alexa_media
- media_player.basement_dot
- media_player.computer_room_dot
- media_player.garage_dot
- media_player.kitchen_dot
- media_player.livingroom_dot
type: tts
message: "The washer is finished"
Mhhh yes this could be a solution, but honestly don’t want to create another automation for that.
Would love to get this into a template for a sensor.
If you want a sensor then just use a similar format as the trigger and use that to set the state of a trigger template sensor.
I’m not sure what the difference is between an automation that sets a boolean or a triggered sensor that sets the state of a sensor. either way you will need to create something.
