Custom Sensor not working after update to 2021.12
as this is my first post in this forum, please be patient :wink: I spent the last couple of days with troubleshooting but didn’t get any useful information so far.
I implemented a custom sensor using ESP32 to read the output from an optical interface from a Siemens UH50 heat meter inspired by this post:
Siemens UH50 / Landis+Gyr ULTRAHEAT T550 und die optische Schnittstelle | Sedelmaier.at
This solution worked for a couple of months now, until I upgraded Home Assistant to 2012.12 a couple of days ago resulting in sensor becoming unavailable.
Connected to USB to get some logs and recognized it got stuck in a boot loop:
[21:18:49]ets Jun  8 2016 00:22:57
[21:18:49]
[21:18:49]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[21:18:49]configsip: 0, SPIWP:0xee
[21:18:49]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[21:18:49]mode:DIO, clock div:2
[21:18:49]load:0x3fff0018,len:4
[21:18:49]load:0x3fff001c,len:1044
[21:18:49]load:0x40078000,len:8896
[21:18:49]load:0x40080400,len:5828
[21:18:49]entry 0x400806ac
[21:18:50][E][esp32-hal-misc.c:111] disableCore1WDT(): Failed to remove Core 1 IDLE task from WDT
[21:18:50][I][logger:214]: Log initialized
[21:18:50][C][ota:458]: There have been 8 suspected unsuccessful boot attempts.
[21:18:50][D][esp32.preferences:114]: Saving preferences to flash...
[21:18:50][I][app:029]: Running through setup()...
[21:18:50][C][wifi:037]: Setting up WiFi...
[21:18:50][D][wifi:370]: Starting scan...
[21:18:55]E (5430) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
[21:18:55]E (5430) task_wdt:  - loopTask (CPU 1)
[21:18:55]E (5430) task_wdt: Tasks currently running:
[21:18:55]E (5430) task_wdt: CPU 0: IDLE0
[21:18:55]E (5430) task_wdt: CPU 1: loopTask
[21:18:55]E (5430) task_wdt: Aborting.
[21:18:55]abort() was called at PC 0x4014da1c on core 0
[21:18:55]
[21:18:55]ELF file SHA256: 0000000000000000
[21:18:55]
[21:18:55]Backtrace: 0x40088ac8:0x3ffbf820 0x40088d45:0x3ffbf840 0x4014da1c:0x3ffbf860 0x40087205:0x3ffbf880 0x40164923:0x3ffbc160 0x4014f327:0x3ffbc180 0x4008b505:0x3ffbc1a0 0x40089d56:0x3ffbc1c0
[21:18:55]
[21:18:55]Rebooting...
I tried compiling the custom component in Arduino IDE, uploaded it to my ESP32 module and everything worked as expected. So i guess there might be some issue with ESPhome.
yaml
esphome:
  platform: ESP32
  board: nodemcu-32s
  includes:
    - sensorMeterHeating.h
wifi:
  ssid: !secret wlan_iot_ssid
  password: !secret wlan_iot_password
  ap:
    ssid: "Esp32 Counter Heating"
    password: "<PW>"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret esphome_api_password
ota:
- platform: custom
  lambda: |-
    auto my_sensor = new SensorMeterHeating();
    App.register_component(my_sensor);
    return {my_sensor->sensor_kWh, my_sensor->sensor_m3};
  sensors:
  - name: "Meter Heating kWh"
    unit_of_measurement: kWh
    accuracy_decimals: 1
  - name: "Meter Heating m3"
    unit_of_measurement: m3
    accuracy_decimals: 2
- platform: wifi_signal
  name: "ESP32 Counter Heating WiFi Signal"
  update_interval: 60s
custom component included in yaml
#include "esphome.h"
#define RXD2 16
#define TXD2 17
// Polling Intervall in minutes
int pollingInterval = 1;
class SensorMeterHeating : public PollingComponent {
 public:
  Sensor *sensor_kWh = new Sensor();
  Sensor *sensor_m3 = new Sensor();
  SensorMeterHeating() : PollingComponent(pollingInterval*60000) { }
  void setup() override {
  void update() override {
    Serial2.begin(300, SERIAL_7E1, RXD2, TXD2);
    Serial2.setTimeout(10000);
    // send init message
    for (int i=0; i <= 40; i++){
        Serial2.write(0x00);
    // send request message
    Serial2.write("/?!\x0D\x0A");
    Serial2.flush();
    delay(500);
    char term = '\n';
    ESP_LOGD("custom", "Identification Message: %s", Serial2.readStringUntil(term));
    ESP_LOGD("custom", "Change Baudrate to 2400");
    Serial2.begin(2400, SERIAL_7E1, RXD2, TXD2);
    char terminator = '!';
    String output = Serial2.readStringUntil(terminator);
    String kWh = substringBetween(output, "6.8(", "*kWh)6.26(");
    int sensorOutput_kWh = kWh.toInt();
    String m3 = substringBetween(output, "6.26(", "*m3)9.21(");
    float sensorOutput_m3 = m3.toFloat();
    ESP_LOGD("custom", "Sensor loaded");
    //publish sensors if not 0
    if (sensorOutput_kWh != 0 && sensorOutput_m3 != 0) {
        ESP_LOGD("custom", "send data");
        sensor_kWh->publish_state(sensorOutput_kWh);
        sensor_m3->publish_state(sensorOutput_m3);
    //ESP_LOGD("custom", strNew);
    //Serial2.flush();
    //Serial2.end();
  String substringBetween(String s, String a, String b) {
    int p = s.indexOf(a) + a.length();
    return s.substring(p, s.indexOf(b, p));
Maybe someone had similar issues after the latest upgrade…
Cheers
normally when it becomes unavailable then it can read or connect.
try to upgrade HA again
go to ESPHome and run the logs under the device in question, see if you are connected and data is coming in
check your entity has the correct name.
Hey there!
I have the same problem with my customer sensor since the update.
I monitored the log and the data is coming to ESPHome. But HA still says the sensor is unavailable
Sorry for the double post, but i found a solution:
i deleted the device for the sensor in HA and restarted the hardware. After that HA told me that there is a new Device to configure and after that i worked fine again.
Would it be possible for you to share the setup?, im interested in reading our central heating Landis+Gyr that is used for swedish “fjärrvärme”.
/Tobias
same here. I have a Landis+Gyr ULTRAHEAT T550. Have you managed to find a solution for this?
hi, I managed to get this working. The C++ code is a bit unstable, I think that’s why it crashes and reboots. Here is my setup:
maybe someone have time to refactor this.
joe
thank you dipo01 for sharing your code!
Nice one, just what i want. does anny one made this stable and everyday usable? maybee a complete guide somewhere?
Thanks in advance.
Do you have a working solution for new ESPHome where the custom component isn’t supported anymore?
hey guys,
i ported the sensor as a new integration and created a pull-request could you please test it?
external_components:
 - source: github://pr#8684
   components: [landisgyr]
  - platform: landisgyr
    energy:
      name: "Meter Heating MWh"
    volume:
      name: "Meter Heating M3"
uart:
    rx_pin: 16
    tx_pin: 17
    rx_buffer_size: 2048
    parity: EVEN
    baud_rate: 300
    stop_bits: 2
    data_bits: 7
Awesome! It works perfectly!
