Hi
I have been using the custom:sonos-card for months without any issues on a amazon tablet but now the dashboard is showing
Custom Element doesnt exist custom:sonos-card
Its working fine via pc or ios device
Any ideas
TIA
Hi
Any ideas
TIA
clearing the cache might work on fire tablet
Hi
I am not using a browser its using the home assistant app but the same on a browser also.
Restarted tablet also
Stuart
You can clear the app cache
Is that within the home assistant app ? I have cleared it through settings on device apps/home assistant clear cache
Stuart
Ok, if you have cleared it from home assistant apk settings page, I don’t have another idea
Fixed it removed the integration and installed an earlier version its working again.
Thanks for your responses
I had same problem.
Re-installed it and did not work. Then I noticed the name
Check the name. Mine was custom:custom-sonos-card
I renamed it custom:sonos-card
and all is well.
Not sure if it is the same card?
