Spartacus
(Spartacus)
February 24, 2024, 10:36pm
1
Hi all,
I need a horizontal stack without borders. If I use the vertical-stack-in-card, it looks good, but the custom-stack-in-card has borders. What is wrong? How can I remove the border, the line between the two cards in the second example? I also need this in a horizontal alignment.
vertical-stack-in-card:
type: custom:vertical-stack-in-card
title: My Card
cards:
primary: '{{ ''online'' if states(entity) == ''on'' else ''offline'' }}'
icon: '{{"mdi:wifi" if states(entity)=="on" else "mdi:wifi-off"}}'
entity: binary_sensor.cupra_born_car_is_online
multiline_secondary: false
layout: vertical
icon_color: '{{ ''green'' if states(entity) == ''on'' else ''red'' }}'
fill_container: false
custom-stack-in-card:
type: custom:stack-in-card
mode: vertical
keep:
border: false
cards:
layout: vertical
layout: vertical
Use card-mod to remove the boarders.
card_mod:
style: |
ha-card {
border: none !important;
mode: vertical
keep:
border: false
cards:
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style: |
ha-card {
card_mod:
style: |
ha-card {
This is the setup I mention in the other thread with Stack-in-Card and Layout Card. Vertical-stack in Card will work with it as well.
play around with `grid-template-columns:
1 column grid-template-columns: 1fr or grid-template-columns: 100%
2 columns grid-template-columns: 1fr 1fr or grid-template-columns: 50% 50% you can adjust these columns percentages to shrink or enlarge the space.
grid-template-columns: 20% 80% or 80% 20% or any other % combo.
grid-template-columns: 1fr 1fr 1fr
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
margin: 0px 0px 0px 0px
cards:
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style: |
ha-card {
card_mod:
style: |
ha-card {
Spartacus
(Spartacus)
February 25, 2024, 12:26pm
4
Good afternoon,
thank you very much! This helps a lot. I checked out the code, and found out a way to combine the diferent modifications. I am playing around with new options and it seems to be that everything is possible…
But one question: I used the vaiable “entity” instead of the entity name, but in the card-mod section this is not working and I have to use the full entity name (binary_sensor.cupra_born_car_is_online). Is this a mistake on my side, or is it as it is?
Here is my code:
cards:
layout:
cards:
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--shape-animation: ping 2s infinite;
--icon-symbol-size: 20px;
--icon-size: 40px;
@keyframes ping {
0% {
box-shadow: 0 0 5px 1px rgba(var(--rgb-green), 0.7);
100% {
box-shadow: 0 0 5px 15px transparent;
ha-card {
{% if
is_state('binary_sensor.cupra_born_car_is_online','on') %}
--card-primary-color:
{%else%}
--card-primary-color:#7E7E7E;
{% endif %}
card_mod:
style: |
ha-card {
…and what I also don’t really understand: Sometimes I can use the visual editor, sometimes it’s not available. I haven’t found out yet when this happens.
