Hey there, i am trying to get the custom state ui to work. I copied the Files to /home/homeassistant/.homeassistant/www/custom_ui and edited the Configuration.yaml as below:
customize:
entity_id: switch.KEQ0170945
custom_ui_state_card: custom_light
state_card_mode: break-slider
slider_theme:
min: 1
max: 255
pin: true
off_when_min: false
report_when_not_changed: false
The log shows me different error: (line 15 is the first line after customize: )
Apr 25 03:21:03 raspberrypi hass[1418]: expected <block end>, but found '?'
Apr 25 03:21:03 raspberrypi hass[1418]: in "/home/homeassistant/.homeassistant/configuration.yaml", line 25, column 5
Apr 25 03:21:03 raspberrypi hass[1418]: ERROR:homeassistant.bootstrap:Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block collection
Apr 25 03:21:03 raspberrypi hass[1418]: in "/home/homeassistant/.homeassistant/configuration.yaml", line 15, column 5
Apr 25 03:21:03 raspberrypi hass[1418]: Config directory: /home/homeassistant/.homeassistant
Apr 25 03:22:16 raspberrypi systemd[1]: Stopping Home Assistant...
Apr 25 03:22:16 raspberrypi systemd[1]: Starting Home Assistant...
Apr 25 03:22:16 raspberrypi systemd[1]: Started Home Assistant.
Apr 25 03:22:20 raspberrypi hass[1446]: ERROR:homeassistant.util.yaml:mapping values are not allowed here
Apr 25 03:22:20 raspberrypi hass[1446]: in "/home/homeassistant/.homeassistant/configuration.yaml", line 16, column 27
Apr 25 03:22:20 raspberrypi hass[1446]: ERROR:homeassistant.bootstrap:Error loading /home/homeassistant/.homeassistant/configuration.yaml: mapping values are not allowed here
Apr 25 03:22:20 raspberrypi hass[1446]: Config directory: /home/homeassistant/.homeassistant
Does anyone have an idea what is going wrong here ?
