Custom temperature sensor
Morning All,
im still quite new to home assistant! I have a three smart TRV’s I am wanting to convert the temperature status into a sensor so I can include it in some bedroom cards that I am making.
I have done the following code which is passing the developer check and restarting fine but I cannot see the sensors anywhere. Am I doing something wrong or looking in the wrong place?
Here is the code:
CONVERT TEMPERATURE OF ROOMS
Riley_temperature:
      friendly_name: 'Rileys Room'
      value_template: "{{ state_attr('climate.rileys_room', 'current_temperature') }}"
Bedroom_temperature:
    friendly_name: 'Bedroom'
    value_template: "{{ state_attr('climate.bedroom', 'current_temperature') }}"
Dressing_temperature:
    friendly_name: 'Dressing Room'
    value_template: "{{ state_attr('climate.dressing_room', 'current_temperature') }}"
Don’t use capital letters.
Thanks, I have removed the capitals and not made any difference.
You have reloaded the YAML, right?
If so, please post the complete sensor file.
here is the full sensor yaml file:
  • platform: systemmonitor
    resources:
    • type: disk_use_percent
      arg: /config
    • type: memory_free
    • type: memory_use
    • type: memory_use_percent
    • type: processor_temperature
    • type: disk_free
    • type: disk_use
    • type: processor_use
  • platform: template
    sensors:
    nextsunrise:
    entity_id: sun.sun
    friendly_name: 'Next Sunrise'
    value_template: >
      {{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom(' %I:%M %p') | replace(" 0", "") }}
    icon_template: mdi:weather-sunset-up
    nextsunset:
    entity_id: sun.sun
    friendly_name: 'Next Sunset'
    value_template: >
      {{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom(' %I:%M %p') | replace(" 0", "") }}
    icon_template: mdi:weather-sunset-down
Minimal configuration of the standard time and date sensor
  • platform: time_date
    display_options:
    • ‘date_time_iso’
Build on the standard sensor to produce one that can be customized
template:
  • sensor:
    • name: “Date and time”
      state: “{{ as_timestamp(states(‘sensor.date_time_iso’)) | timestamp_custom(’%A %B %-d’) }}”
      icon: “mdi:calendar-clock”
  • sensor:
      state: “{{ as_timestamp(states(‘sensor.date_time_iso’)) | timestamp_custom(’%A %B %-d, %I:%M %p’) }}”
riley_temperature:
bedroom_temperature:
dressing_temperature:
Ok, this is a little hard to read because the code is not set in backticks (see no. 11 of the community guidelines). If I can read it correctly, you have placed the legacy sensor code under the template domain. However, legacy template sensors belong to the domain sensor.
