Hello all!
I’m using Zigbee2MQTT and i have a Sonoff TRV
The issue is that if i use the Sonoff TRV thermostat card the thermostat sensor is inside the TRV and the temperature is getting up pretty quickly.
I have another temperature sensor inside the room and i was wondering is there a way to use the thermostat sensor that it’s not inside the TRV, but the one i have separately (it’s this one.
I tried using generic_thermostat, but it requires on/off switch and the TRV doesn’t have it.
I have another idea to make a flow inside nodeRED using min/max custom values and to have a check every 5 mins if the temperature is below MIN start the TRV and set occupied_heating_setpoint
it to max (35) if the temperature is above MIN set occupied_heating_setpoint
to min
