I hope this is the right category to post that Project. Because the Raspberry Pi Zero in SHPI.zero is too weak to display the Home-Assistant Lovelace interface in the browser, I wrote a small Home-Assistant GUI for the Raspberry Pi Zero. It’s not quite bug free yet, but at least it works
I decided to opensource the code, because I want to give something back to the community, which gave me and many others so much with the Home-Assistant and the countless integrations.
But I must say that the project is in a very early alpha and I hope you enjoy it anyway. Feel free to contribute to make it better
Sorry it got preempted by some other gadgets coming in…
When I get to it I will definitely contact you and will also post any issues found on github.
Whats the best platform for you to get in touch? here? github? your blog?
when I run sudo apt install libsdl2-dev libsdl2-image-dev libsdl2-mixer-dev libsdl2-ttf-dev pkg-config libgl1-mesa-dev libgles2-mesa-dev python-setuptools libgstreamer1.0-dev git-core gstreamer1.0-plugins-{bad,base,good,ugly} gstreamer1.0-{omx,alsa} python-dev libmtdev-dev xclip xsel libjpeg-dev
I get a lot of errors related to “read-only file system”:
Err:1 http://archive.raspberrypi.org/debian buster/main armhf gstreamer1.0-omx-rpi armhf 1.14.4-1+rpt1
Could not open file /var/cache/apt/archives/partial/gstreamer1.0-omx-rpi_1.14.4-1+rpt1_armhf.deb - open (30: Read-only file system) [IP: 176.126.240.84 80]
It is not a bug in Dashzero, more some missing piece of info in the setup description…
Any ideas how to proceed?
(installing the python stuff did work, and editing the config files, however unsure which main.py to start…, just rebooted and the standard SHPI main application was started)
Hi, I am trying this on a remaining pi zero. This seems to be not updated anymore but I am still want to give it a try.
Some basic stuff were not working:
ics module need to be installed as well
kivymd 0.104.1 module is not working you have to install manually version 0.104.2.
Unfortunatly it is still not working:
File "main.py", line 104, in <module>
MainApp().run()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/app.py", line 949, in run
self._run_prepare()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/app.py", line 919, in _run_prepare
root = self.build()
File "main.py", line 83, in build
self.root = MainScreen(config)
File "main.py", line 31, in __init__
self.navigation = Navigation(config['rooms'])
File "/home/pi/dashzero/gui/core/navigation.py", line 28, in __init__
self.add_widget(NavigationItem(room))
File "/home/pi/dashzero/gui/core/navigation.py", line 8, in __init__
super(NavigationItem, self).__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/boxlayout.py", line 145, in __init__
super(BoxLayout, self).__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/layout.py", line 76, in __init__
super(Layout, self).__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivymd/uix/tab.py", line 736, in __init__
self._update_text()
File "/home/pi/.local/lib/python3.7/site-packages/kivymd/uix/tab.py", line 762, in _update_text
f"{self}: [UID] = [{self.uid}]:\n\t"
ValueError: <gui.core.navigation.NavigationItem object at 0xb1122a30>: [UID] = [164]:
No valid Icon was found.
No valid Title was found.
Icon = ''
Title = ''
