is there some bug? my home is at the red dot. north of belgium.
All information on the screenshot is coming from buienradar data. but the buienradar rain forecast tells me there is no rain now and the next 2 hours. On my android widget from buienradar itself there is the entire 2 hours buien on the widget.
I use this card for a while now, but it is only showing up half the time, if I refresh the page it appears again.
Is there a solution for this problem?
I liked this integration, so I tried to rebuild it with data from clima cell (they offer precipitation forecast for every minute, 10, 15, 30… Minute) and visualization by mini graph card.
Its far from perfect but does the job. I was just wandering, if it would be possible to add climacell data to the buienradar integration, as it is in a better design and shape and would it make accessible to almost to proably users worldwide.
Unfortunately I do not know any js and therefore can not help out - its just an idea.
Can you access my Github fork of the original project? The “ buien-rain-card.js ” should have changes marked “v0.0.6”. If yes, then deploy this file to your environment as described earlier in this thread. Make sure that the new code is used, and not a previously cached version. Easiest is to add or increase the version number of your HA Resource definition, then refresh (F5) the Lovelace Overview page where you added the card:
URL: /local/buien-rain-card.js?v=0.0.6
The versions in the resource definition and in the file does not need to match, but it may help troubleshooting if you try different versions over time, because the resource version is actually shown in the HA error logs if something goes wrong.
Just for the record, v.0.0.6 also includes the update improvements made by @bouwew.
