Probably a question for @andrey - does custom UI support hiding the stop button for the cover component? My Cover (garage door) does not support stop, currently…
This should definitely be supported by the main UI.
What cover platform is it?
It is the myq
platform
Looking for the same thing for MQTT Cover.
I’ve tried commenting out payload_stop
to no avail.
I need help on this, I use Mqtt Cover but I have only one button for all, up/stop/down
Looking to remove the stop button as well, removing the payload_stop or setting it to “” or false didn’t work…
It seems it’s not possible to disable the button
PR to fix the issue
