cavern
January 16, 2021, 9:50am
154
card-mod did the trick. thanks again @Mariusthvdb . Although Iām not too acquainted yet to JavaScript and CSS so I more or less copied examples.
I believe there is a way to better optimize my code as it mostly duplicates three times :
badges:
- entity: person.anne_laure
style:
ha-state-label-badge:
ha-label-badge:
:host {
{% if is_state('person.anne_laure','home') %} --label-badge-red: green;
{% else %} --label-badge-red: red;
- entity: person.emmanuel
style:
ha-label-badge:
:host {
{% if is_state('person.emmanuel','home') %} --label-badge-red: green;
- entity: person.valentine
style:
ha-label-badge:
:host {
{% if is_state('person.valentine','home') %} --label-badge-red: green;
exactly, hence my request above if we could use entity
instead of the entity name in the template. If so, we could simply use a yaml anchor:
badges:
style: &badge_style
ha-label-badge:
:host {
{% if is_state(entity,'home') %} --label-badge-red: green;
style: *badge_style
- entity: person.etc
style: *badge_style
we might have to ask Thomas Loven or Kendell about this, since they wont be reading along here
see š¹ Card-mod - Super-charge your themes! for the relevant thread
NM! Found it already: use config.entity
even 1 line shorter:
badges:
- entity: person.me
<<: &badge
style:
ha-label-badge:
.label-badge .label span{
{% if is_state(config.entity,'home') %} color: purple;
{% else %} color: black;
:host {
{% if is_state(config.entity,'home') %} --label-badge-red: gold;
{% else %} --label-badge-red: grey;
- entity: person.she
<<: *badge
depending on what you want to define under the anchor.
cavern
January 16, 2021, 3:37pm
156
I understand the syntax (never used the &myvariable/*myvariable scheme before) and discover the config.entity possibility. Have to read a bit about that config.entity way of doing.
HA is an infinite montain of knew knowledge for me
yeah these are Yaml Anchors, and can be defined āon the flyā so to speak. Anything written after the definition character <<: &anchor_name
will be copied (āmergedā in anchor lingo) when you put <<: *anchor_name
anchors are defined per yaml file. Meaning, if you need the same anchor in another file you need to recreate it first.
hereās a Yaml primer by Thomas, read all the way down: http://www.thomasloven.com/blog/2018/08/YAML-For-Nonprogrammers/
since examples can be easier to understand than the above primer, (there are 2 different ways to create Anchors) have a look at more examples in https://github.com/Mariusthvdb/custom-ui/blob/2ba4168e9554e9290bc3f2c872316a522639f2e4/examples.md
cavern
January 16, 2021, 4:04pm
158
thanks, Iāll read that.
the anchor syntax is simple yet powerful. Iāll probably reuse it as I hate repeating code.
basti4k
(Sebastian)
January 31, 2021, 12:15pm
159
Change the ICON Color dont work for me
customize:
binary_sensor.office_window_xiaomi_1_openclose:
friendly_name: BĆ¼ro Fenster
device_class: window
templates:
rgb_color: "if (state === 'on') return [200, 100, 30]; else return [10, 20, 30];"
But this Example dont work
if i open the Window, the icon color is the Frontend Style:
ha-icon[data-domain="binary_sensor"][data-state="on"]
color: var(--paper-item-icon-active-color, #fdd835);
default Color.
What I need, is when the window is open, then change the color: --color-red-error-1
or RGB
i hope you an help me! Thanks all
You should use icon_color: and not rgb_color:
Also, check the correct color format to use, you can find many examples in the examples ;-)-
basti4k
(Sebastian)
January 31, 2021, 1:38pm
161
yes, i test so many ways, but nothing works.
here the new Test in customize File:
icon_color: "{% if is_state('binary_sensor.office_window_xiaomi_1_openclose', 'on') %}rgb(255, 214, 10){% else %}rgb(255, 255, 255){% endif %}"
icon_color
can only be set using custom-ui , which uses javascript templates, and not jinja templates like you use.
did you install custom-ui?
basti4k
(Sebastian)
February 1, 2021, 6:09pm
163
yes i install custom-ui
frontend:
themes: !include_dir_merge_named themes
extra_module_url:
- /local/custom-ui/custom-ui.js
/usr/share/hassio/homeassistant/www/custom_ui/custom-ui.js
is that okay?
the yaml in customize:
templates:
icon_color: '{% if is_state("binary_sensor.office_window_xiaomi_1_openclose", "on") %}rgb(255, 214, 10){% else %}rgb(255, 255, 255){% endif %}'
yaml office:
- type: glance
show_name: true
style: !include ../includes/style_entities.yaml
entities:
- entity: light.light1test
- sensor.buro_dect301_1_temperature
- entity: binary_sensor.office_window_xiaomi_1_openclose
basti4k:
templates:
this is not ok. As I said before.
please check the many examplesā¦ you started out well Custom UI - icon color change - #159 by basti4k but somehow changed from a JS template to a jinja templateā¦ why?
try:
templates:
icon_color: >
if (state == 'on') return 'rgb(200, 100, 30)';
return 'rgb(10, 20, 30)';
and you should be set
basti4k
(Sebastian)
February 2, 2021, 9:36am
165
Hi and many thanks for your help!!
Unfortunately I have no idea where and what the difference is to JS template or jinja template i test the examples
What is the right way for installation?
Can I see if everything is installed correctly and Custom UI is working properly?
templates:
icon_color: >
the new code dont work
Your code is simple and I understand it. But it does not work
apparently it isnt
did you read the readmeā¦ ? Itās all in there.
btw:
extra_module_url:
you are not using the same dash/underscore in the path. use either ā_ā or ā-ā in both
basti4k
(Sebastian)
February 2, 2021, 10:30am
167
OMG THANKS, yes in the Readme is the foldername: custom_ui
i rename the folder:
/usr/share/hassio/homeassistant/www/custom-ui/custom-ui.js
configuration.yaml
frontend:
extra_module_url:
The file is now loaded in the developer tool:
CUSTOM-UI (JS) Version 20201218 adapted for HA 2020.X.X +
After ārestartā it work
QA: if i edit a āicon_color: >ā part, the color. Then always have to restart the completely HA?
no, as a rule of thumb, all customizations are reloaded if you click config/server_control RELOAD LOCATION & CUSTOMIZATIONS.
Sometimes a refresh of the browsers helps. On occasion, none of this kicks in and the next restart it will be fine.
basti4k
(Sebastian)
February 2, 2021, 11:30am
169
Thanks it works perfect!
i see in the example the way, for the color varible:
configuration.yaml
frontend:
extra_module_url:
themes/ing_dark.yaml
# Status Color
alert_red:
paper-item-icon-color: "var(--color-red-1)"
alert_blue:
paper-item-icon-color: "var(--color-blue-1)"
# Theme
ING Dark:
# Fonts
color-red-1: "rgba(247,53,67,1)"
color-blue-1: "rgba(6,169,244,1)"
customize:
templates:
icon_color: >
if (state == 'on') return 'alert_red';
return 'alert_blue';
where?
as stated, any valid css color value can be used. Not sure if that variable you created in your theme is causing your issue, please check this:
icon_color: >
if (state == 'on') return 'var(--primary-color)';
return 'steelblue';
which works fine.
You canāt though use the theme name for the color_name, which is what you are doing.
basti4k
(Sebastian)
February 2, 2021, 12:39pm
171
hehe, why is it so easy ?
Thanks a lot ! Works great !
maybe you can still include this example for others:
# Some examples using custom-ui.
This is an excerpt of my own package, and can be used
directly if you copy it to your own homeassistant structure and activate packages. Of
course other methods work also, like pointing to a dedicated customize file, and
referencing that in your configuration.yaml
Note that the triple `===` which is used throughout the community and examples on the
original repo are not necessary. `==` suffices. Secondly, always use a guard for unexpected states.
Of course this holds for Jinja templates in HA too...
The guard is used by setting the `else` clause, which in the examples below are on the
last lines, starting with 'return'. Dont need to use the word `else` itself, though it
will be valid if you do.
Lastly, remember to delimit the lines with a `;` .
Why use custom-ui? 2 huge reasons:
# Icon color
This file has been truncated. show original
templates:
icon_color: >
if (state == 'on') return 'var(--color-red-1)';
return 'var(--paper-item-icon-color)';
zgadson
(Zach)
March 3, 2021, 4:40pm
172
What about when you need to change the icon color based on the state of an entirely separate entity?
I have a button to execute a script on my dashboard, but because a script has no state the script toggles a boolean on or off. So even though my button entity is for a script, the script icon needs to changed based on the state of the associated boolean.
Hereās what I have in my customization file but itās not working:
script.script_fan_speed_0:
friendly_name: 'Off'
icon: mdi:fan-off
templates:
icon_color: >
if is_state('input_boolean.boolean_fan_speed_0','on') return 'green';
return 'white';
did you read the docs and check the examplesā¦?
Guess not, because you use a mix between Jinja and JS templates, and not the required pure JS.
also, there are a couple of āglobalā examples.
# using an attribute of another (global) entity
sensor.power_consumption:
templates:
icon_color: >
if (entities['sensor.smart_meter'].attributes.power > 3000) return 'red';
return green;
or use the state:
binary_sensor.ha_update_available:
templates:
unit_of_measurement: >
if (entities['sensor.ha_available_version']) return entities['sensor.ha_available_version'].state;
return 'starting up';
btw, if you are using buttons in the Lovelace config, you might be better of using card-mod
