Custom UI - icon color change
OK, I added my sensor.bedroom_temperature sensor to my Bedroom group, without making any other changes, and it came up as follows:
So the whole entry was themed with the colour.
I then changed it to make it specific to just the icon, and the following works, so give this a try:
  customize:
    sensor.bedroom_temperature:
      templates:
        rgb_color: >
          if (state > 25) {
            return [0, 128, 0];
          } else if (state >= 18 ) {
            return [223, 76, 30];
          } else {
            return [35, 76, 99];
Thanks for helping out!
Looks like the rgb_color works only on the icon (-for me) when in a group, not the text. The rgb_color works not for the sensor when on the default view.
Do you know if there are a code for the color within the default sensor view?
Yeah if you use “rgb_color” as shown in my second post, it will only change the icon colour when in the group.
If you use “theme” as shown in my first post, it will change the colour of the badges (the circular representations shown in your second image). If you then add it to a group, whilst using theme, it will change the icon, text and value, as I show in the first image of my second post!
To use theme, you need to define the colours under the theme section of the front end - I’m at work now, but when I get home I will post that config for you.
Don’t worry, it confused the hell out of me (I find CustomUI incredibly confusing as it is!), so am happy to help!
@Tomahawk right, hopefully this will all be clear enough :slight_smile:
To change the badge colour, we use theme, and define the colours as hex:
homeassistant:
  customize:
      templates:
        theme: >
          if (state > 25) {
            return 'hot';
            return 'comfortable';
          } else {
            return 'cold';
frontend:
  themes:
    cold:
      primary-text-color: '#447ebc'
      label-badge-red: '#447ebc'
    comfortable:
      primary-text-color: '#629e51'
      label-badge-red: '#629e51'
    hot:
      primary-text-color: '#bf1b00'
      label-badge-red: '#bf1b00'
That will produce this: image
If we then add the sensor to a group, with the above left in place, it will change the text and state to the relevant colour, as shown here:
If we want to just change the icon colour, then we use rgb_color and define the colours as R, G and B values on a 0-255 scale:
homeassistant:
  customize:
      templates:
        rgb_color: >
          if (state > 25) {
            return [191,27,0];
            return [98,158,81];
          } else {
            return [68,126,188];
You can easily convert between RGB and Hex using this site:
Hope that helps!
Thank you so much!
Is it at all possible to change the background color within the sensor circle, when it is displayed on the default view?
sure, do anything you like:
39
well, almost. Havent found a way to distinguish between border colors of the badge and label. Also, no changing of the label text is possible (yet). Other than that, most things can be customized…
for the badges i use my dedicated frontend themes file, you might be able to adapt it to your own likings:
# Badge-themes in order of severity, either up or down
#source https://github.com/home-assistant/home-assistant-polymer/blob/master/src/resources/ha-style.html
# /* for label-badge */
#    --label-badge-background-color: white;
#    --label-badge-text-color: rgb(76, 76, 76);
#    --label-badge-red: #DF4C1E;
#    --label-badge-blue: #039be5;
#    --label-badge-green: #0DA035;
#    --label-badge-yellow: #f4b400;
#    --label-badge-grey: var(--paper-grey-500);
green_badge:
  label-badge-red: green
  label-badge-border-color: lightgrey
  label-badge-text-color: green
#  label-badge-blue: blue
#  label-badge-green: black
#  label-badge-yellow: yellow
#  label-badge-grey: grey
grey_badge:
  label-badge-red: grey
  label-badge-text-color: grey
black_badge:
  label-badge-red: black
  label-badge-text-color: black
brown_badge:
  label-badge-red: brown
  label-badge-border-color: brown
  label-badge-text-color: brown
orange_badge:
  label-badge-red: orange
  label-badge-border-color: orange
  label-badge-text-color: orange
blue_badge:
  label-badge-red: blue
  label-badge-border-color: blue
  label-badge-text-color: blue
yellow_badge:
  label-badge-border-color: yellow
  label-badge-background-color: lightgrey
  label-badge-text-color: yellow
red_badge:
  label-badge-text-color: red
can I use this as single package?
You’re welcome - I see @Mariusthvdb already answered the background question. Have fun!
Sorry @anon35356645, I’m afraid I have never used packages so am not sure.
yep very wel possible.
Keep it all together nice and tidy.
just beware to have the proper headers in place, along with careful indenting.
strange behavior might occur though. Groups declared in the packages aren’t shown after one clicks the reload groups button in configuration. Also, in my setup, script behave unreliably when declared in the packages, so I always put these in their dedicated /config/scripts folders.
Other than that, packages are very nice to have. very easy to take out also when testing and debugging…
I already use packages, but never with
homeassistant:
  customize:
wondering if in packages do I have to put homeassistant: or not?
for sure, if you want to customize, it should be under homeassistant:
Just follow the order of your configuration.yaml
It does not work with Badges in state cards :frowning:
Have you an idea for this ?
I have try all these properties:
primary-text-color
label-badge
ha-label-badge-color
label-badge-blue
Bu no one works.
The color of text and icon are been modified only in detail card.
What do you mean by “it”?
Badge and state-card examples are here: Custom UI - icon color change - #15 by davefi
Badge background is here: Custom UI - icon color change - #17 by Mariusthvdb
Yes i am having the same problem it does not work it just stays red.
   sensor.window_eliott_top:
      friendly_name: Eliott
      templates:
      theme: >
          if (state = 'Open') {
            return red_badge;
          } else (state = 'Closed' ) {
            return green_badge;
If I do this the Badge goes green.
     theme: green_badge
This is the frontend stuff
frontend:
  themes:
    green_badge:
    red_badge:
Is rgb_color working anymore with custom_ui for you all? Looks like we need to switch to hs_color
homeassistant:
  customize:
    sensor.central:
      templates:
        rgb_color: [255,0,0]
is this expected to work for example ?
I am getting this :
2018-04-03%2000_15_40-Home%20Assistant
primary-text-color: works to change a text color.
But rgb_color, label-badge-red and any other combination not working to change badge color.
Hi @anon57099626
What transport sensor are you using for your tube I.e. central line ?
thanks @Vlad for your comment, looking at https://github.com/andrey-git/home-assistant-custom-ui/issues/126 it seems that rgb_color was working to modify the icon colors, but now it’s broken.
@bachoo786 https://www.home-assistant.io/components/sensor.london_underground/
