Custom UI - icon color change
27 now. But where are they???
Do I need to safe-guard these?
switch.coffee_maker:
  icon: mdi:toggle-switch
switch.dryer_master_power:
switch.garage_door_opener:
  icon: mdi:light-switch
switch.kitchen_blind_1:
  icon: mdi:window-shutter
switch.kitchen_blind_2:
switch.kitchen_blind_3:
switch.bedroom_blind:
switch.mimolite_switch:
  icon: hass:power
  device_type: garage
switch.nzw30_smart_switch_switch:
switch.patio_door_blind:
switch.pole_lamp:
  icon: hass:light-switch
switch.rgbw_dimmer_module:
  icon: hass:toggle-switch-off-outline
switch.sonoff_1000627ef1:
switch.sonoff_1000ca1644:
switch.sonoff_1000ca5efa:
switch.sonoff_inching:
switch.tyzb01_iuepbmpv_ts0121_on_off:
switch.washer_master_power:
light.bedroom_lamps:
  icon: hass:lightbulb-multiple
switch.switchlinc_relay_dual_band_1f_b5_4a:
switch.switchlinc_relay_dual_band_1f_b3_c5:
switch.switchlinc_relay_dual_band_1f_b7_25:
its a matter of elimination. comment them all and see if the error is gone? ok?
than enable half of them and retry. error still gone? enable half of the rest. if not, check in the last enabled sectionā€¦
but, you dont need to do this in all your custom-ui templates, just the ones where the state is created during startup. Mostly HA template sensors, or things made by python scripts etc etc
wouldnt think so no, only templates. but, with the method above, its easily checked
btw, a state.state will most likely ever be ā€˜unavailableā€™ , not ā€˜Unavailableā€™. you need to check the true state in the state machine, not what is shown in the Frontend
huh? I do not understand that statement!
id use
if (state && state.state == 'unavailable')
but, you forget even state can be none, so, you either want to check for state alone
if (state) and, if state exists, you can continue. Or, you check for
if (state.state != 'unavailable') and continue.
see:
        icon_color: >
          if (attributes && attributes['dst active']
              && attributes['dst active'] == true )
          return 'maroon';
          return 'green';
it checks if attributes are available, And if a certain attributes is available, And then if that attributes is true. in all other cases it returns the exception
I commented those out and zero errors on this bootā€¦
well, there you have it :wink: system never liesā€¦
what switches are those? template switches maybe?
No, those are real switches. I uncommented them and no errors from them this time. Go figure!
Just 2 left:
  - name: Period of day
    unique_id: period_of_day
    state: >-
      {% if (as_timestamp(state_attr("sun.sun","next_dusk"))) - (as_timestamp(state_attr("sun.sun","next_setting"))) < 0 %} Dusk
      {% elif (as_timestamp(state_attr("sun.sun","next_rising"))) - (as_timestamp(state_attr("sun.sun","next_dawn"))) < 0 %} Dawn
      {% elif (state_attr("sun.sun","elevation")) < 0 %} Night
      {% else %} Day
      {% endif %}
    icon: >-
      {% if is_state('sun.sun', 'above_horizon') %} mdi:weather-sunny
      {%elif (as_timestamp(state_attr("sun.sun","next_dusk"))) - (as_timestamp(state_attr("sun.sun","next_setting"))) < 0 %} mdi:weather-sunset-down
      {% elif (as_timestamp(state_attr("sun.sun","next_rising"))) - (as_timestamp(state_attr("sun.sun","next_dawn"))) < 0 %} mdi:weather-sunset-up
      {% else %} mdi:weather-night
      {% endif %}
thats a core template sensorā€¦
forget about those, use:
      - unique_id: part_of_day
        name: Part of day
        state: >
          {% set hour = now().hour %}
          {% if hour in range(0,6) %} Night
          {% elif hour in range(6,12) %} Morning
          {% elif hour in range(12,18) %} Afternoon
          {% else %} Evening
          {% endif %}
        <<: &pod_icon
          icon: >
            {% if hour in range(0,6) %} mdi:weather-night
            {% elif hour in range(6,12) %} mdi:weather-sunset-up
            {% elif hour in range(12,18) %} mdi:weather-sunny
            {% else %} mdi:weather-sunset-down
            {% endif %}
unless you specifically want to hold to those timestampsā€¦
I also have this but do not have it in configuration.yaml!
2022-02-04 03:04:40 WARNING (MainThread) [homeassistant.components.version] Configuration of the Version platform in YAML is deprecated and will be removed in Home Assistant 2022.4; Your existing configuration has been imported into the UI automatically and can be safely removed from your configuration.yaml file
Also already removed from configuration.yaml:
Logger: homeassistant.components.androidtv.config_flow
Source: components/androidtv/config_flow.py:179
Integration: Android TV (documentation, issues)
First occurred: 3:04:56 AM (1 occurrences)
Last logged: 3:04:56 AM
Host [192.168.1.91] already configured. This yaml configuration has already been imported. Please remove it
And I canā€™t for the life of me the source for this!
Logger: homeassistant.helpers.script
Source: helpers/script.py:638
First occurred: 3:05:29 AM (1 occurrences)
Last logged: 3:05:29 AM
Error in 'condition' evaluation: In 'template' condition: UndefinedError: list object has no element 157
I know! it should be available pdq. If I put that into template editor itā€™s fine!
haha, well, yes, but you cant drop all your yaml errors in here :wink:
LOL! thought Iā€™d tryā€¦
Have a good night (or day, where ever you are)ā€¦and thanks!
@mariustvbd, question: is it possible to change the colour of an icon based on the state of a source. For example Apple TV has various sources, if one source is playing can the icon related to that source change in colour? I am using the button card.
what I came up with is:
- type: button
icon: mdi:television
icon_height: 80px
state_color: red
name: SET TOP BOX
show_state: true
styles:
icon:
- color: |
if (state_source[ā€˜media_player.apple_tvā€™, ā€˜GSE IPTV PROā€™].state == ā€˜playingā€™) return ā€œredā€;
return ā€œdarkgreenā€;
tap_action:
action: call-service
service: script.lounge_box
service_data: {}
target: {}
hold_action:
service_data: {}
target: {}
but that doesnā€™t seem to be working. Any help would be highly appreciated
first of, your template is valid for custom:button-card, and not core button.
You could however try a template like that with card-mod, but then youā€™d need to change it to Jinja, and not use Javascript
in both cases, its not a custom-ui question, and in the wrong spot here because of that.
besides that, custom-ui is currently partly broken, because of Breaking! HA 2022.4 (partly) breaks Custom-ui Ā· Issue #48 Ā· Mariusthvdb/custom-ui Ā· GitHub, so dont hold your breath on getting that back.
in all cases: format your code correctly please (using the </> button in the toolbar) , so we can see what youā€™re actually posting
A simple button should show the icon highlighted if the mower is mowing. I donā€™t have any idea why itā€™s not working. Here my code in customize.yaml:
mower.mahndy:
  templates:
    icon_color: if (state == 'mowing') return 'rgb(214,162,69)';return 'rgb(102,102,102)';
could be many things, without anything further we cant help you.
please show the frontend config of the card
and show the Settings/About bottom line on custom-ui
Hi all, I have a pair of custom-buttons with following lovelace config:
            - type: custom:button-card
              entity: input_boolean.hvac_bedroom_preset
              icon: mdi:snowflake
              show_state: false
              show_label: false
              entity: sensor.temperature_bedroom
              icon:  mdi:thermometer
              show_name: false
              show_state: true
resulted in different icon's color
Is there any way how to ā€œunifyā€ color of icons?
I have some of these within my whole config and not able to solve it :woozy_face:
Any advice please?
with button-card, you dont need custom-ui at all.
any color setting can be done in the styles directly.
for further instructions/exmaples, youā€™d best hop over to the dedicated thread on custom:button-card
Sorry for my ignorance. Thanks
Did the recent updates in Jan 2023 remove the icon color changes in customize.yaml?
For example:
templates:
  icon_color: if (state == 'on') return 'red';
