Custom UI: Tiles
edit the problem with my code below is due to a typo, it should be row_span not row-span
I’ve tried row_span but something went wrong… The row spans and row numbers look like they should work but there must be something I’m missing? (I’m trying to make kitchen with a bulb a half height strip)
homeassistant:
  customize:
    input_text.lights:
      custom_ui_state_card: state-card-tiles
      config:
        columns: 3
        # row_height: 75px
        row_height: 35px
        # column_width: 75px
        gap: 15px
        color: '#555B65'
        color_on: '#F0C209'
        color_off: '#555B65'
        entities:
          #Lights
          - entity: group.lounge_lights
            label: Lounge
            icon: mdi:ceiling-light
            column: 1
            row: 1
            row-span: 2
          - entity: group.lounge_lamps
            label: Lounge
            icon: mdi:lamp
            column: 2
            row: 1
            row-span: 2
          - entity: group.study_lamps
            label: Study
            icon: mdi:school
            column: 3
            row: 1
            row-span: 2
          - entity: group.kitchen_lights_all
            label: Kitchen
            icon: mdi:lightbulb
            column_span: 3
            row: 3
          - entity: light.kitchen
            label: Kitchen
            icon: mdi:door
            column: 1
            row: 4
            row-span: 2
          - entity: light.kitchen_main_led
            label: Kitchen
            icon: mdi:led-strip
            column: 2
            row: 4
            row-span: 2
          - entity: group.kitchen_spots
            label: Kitchen
            icon: mdi:spotlight-beam
            column: 3
            row: 4
            row-span: 2
          - entity: group.hall_lights
            label: Hall
            column: 1
            row: 6
          - entity: group.landing_lights
            label: Landing
            column: 2
            row: 6
            row-span: 2
Put row_span: 1 in.
Any way to hide a tile according to state?
I tried adding…
            templates:
              hidden: "return (state === 'off' );"
to the tile code itself and also the entity’s own customize entry but no joy, no errors, button still there regardless :frowning:
It was a good suggestion, but unfortunately it didn’t help. I did spot I was missing a row-span: 2 on group.hall_lights but still the same issue.
Just to check, did you mean row-span: 1 on group.kitchen_lights_all? If not I also tried setting exiting row_span: 2 to 1.
I did yes, that’s all I have different for my half height told. Have you tried removing the big gap by making it row 2 to see what happens?
To get rid of this, just clear your browser cache (on the iPhone - settings | safari | clear history and website data)
A typo got the better of me - I was using row-span instead of row_span! doh!
Hi @simbesh
have read this thread for 3 times now, but just cant find the code to your Master group, and the Room switch you’re showing here.
Please would you care to share ?
Thanks,
Marius
I have this same problem. I cannot get row 2 and row 3, just row 1 appears. I have tried adding row_span, deleting cache, resetting the browser, creating a panel, nothing has worked.
The scripts for each of the button works in the script section when I press activate.
I have worked on this for 2 weeks with no solution. My install is latest hass.io and custom ui updated as well.
Here is my config:input_text.tiles_harmony_remote:
config:
columns: 3
column_width: 50px
row_height: 50px
gap: 4px
color: ‘#555B65
color_on: ‘#D5D619
color_off: ‘#BBBEC2
entities:
- entity: script.tvmenu
icon: mdi:menu
column: 1
row: 1
row-span: 1
- entity: script.arrowup
icon: mdi:arrow-up-bold
column: 2
row: 1
- entity: script.tvvolumeup
icon: mdi:volume-plus
column: 3
row: 1
- entity: switch.arrowleft
icon: mdi:arrow-left-bold
column: 1
row: 2
row-span: 1
- entity: script.tvcheck
icon: mdi:check-circle
column: 2
row: 2
- entity: script.arrowright
icon: mdi:arrow-right-bold
column: 3
row: 2
- entity: switch.tvback
icon: mdi:backup-restore
column: 1
row: 3
row-span: 1
- entity: script.arrowdown
icon: mdi:arrow-down-bold
column: 2
row: 3
- entity: script.tvvolumedown
icon: mdi:volume-minus
column: 3
row: 3
No need to use a room template switch, just use a group. See my code example above. Custom UI: Tiles
The group would have all the entities required for a master switch, and other tiles would have those entities individually.
Sorry my fault, my code that you used had a typo, it should be row_span.
Also code pasting tip, use three back ticks above and below your code to properly format it in the post.
Sure, Thx. Know and use that;-) just liked the setup very much and would have hoped for a code-share… :+1:
Hello, they finally appear after many hassio reboot and empty cache. Hope you will solve it soon.
Thanks tried that. Have rebooted and emptied cache over 20 times, tried different os and web browsers - same results. So its got to be my configuration on hassio. I can get the tiles to move to different rows or columns but no more than 3 icons are visible at a time. I am trying to replicate your setup.
I will be back home tomorrow in the evening, will post my config for you.
Thanks to eddi89 over on GitHub, he’s helped explain how to create a smaller height tile and how to have lowercase text.
First thing to note is that the minimum tile size is 50x50px, and this is why I was struggling to make a smaller tile in my earlier posts. To get around this you use style_template:
Lowercase text: style_template: "return 'text-transform: none;';"
Smaller tile height: style_template: "return 'min-height: 25px;';"
Combined: style_template: "return 'text-transform: none; min-height: 25px;';"
All together this is how my tiles now look, with the code for this below. Hope it helps others!
32
homeassistant:
  customize:
    input_text.lights:
      config:
        columns: 3
        row_height: 25px
        gap: 10px
        text_size: 1em
        color: '#555B65'
        color_on: '#F0C209'
        entities:
          #Lights
            label: Lounge
            column: 1
            row: 1
            row_span: 2
            label: Lounge
            icon: mdi:lamp
            column: 2
            row: 1
            row_span: 2
            label: Study
            icon: mdi:school
            column: 3
            row: 1
            row_span: 2
            label: Kitchen All
            icon: mdi:power
            column_span: 3
            row: 3
            label: Kitchen
            icon: mdi:door
            column: 1
            row: 4
            row_span: 2
            label: Kitchen
            icon: mdi:led-strip
            column: 2
            row: 4
            row_span: 2
            label: Kitchen
            column: 3
            row: 4
            row_span: 2
            label: Hall
            column: 1
            row: 6
            row_span: 2
            label: Landing
            column: 2
            row: 6
            row_span: 2
          - entity: light.bed_two
            label: Bed2
            column: 1
            row: 8
          - entity: light.bedside2
            label: Bed2
            icon: mdi:lamp
            column: 2
            row: 8
          - entity: switch.bed_two_floor_light
            label: Bed2
            icon: mdi:power-plug
            column: 3
            row: 8
          - entity: light.bed_three
            label: Bed3
            column: 1
            row: 9
          - entity: light.bedside3
            label: Bed3
            icon: mdi:lamp
            column: 2
            row: 9
          - entity: switch.bed_three_floor_light
            label: Bed3
            column: 3
            row: 9
Can we use this for just informational entities (where there is no action involved)? I have a bunch of entities for the stock market futures.
Instead of taking up all the space, I was wondering if I can display them as tiles with color depending on whether the change is positive of not.
Useful update (thanks again eddi89).
My screenshot in the previous post has text either next to the icon or below, depending on text length.
To ensure text is below the icons, use label_sec:
44
awesome, this def helped me- thanks for sharing!
did label_sec work (i cant seem to get the text under the icon)
Yep, here is my code (just need to make sure tile size is large enough)
            label_sec: Lounge
            column: 1
            row: 1
            row_span: 2
