I was looking into doing that at the very beginning of this project but it was not very reliable. I’ll try to have a second look now that I’m more comfortable with the code.
I think my error turned out to be an issue on my end. Seems like when you upgrade, you have to redo the nest integration every time (I think that someone else has called that out before).
Hi @kuuji, it’s working great at the moment, so more of a feature request really. Would it be possible to allow custom sizing and padding of the buttons please?
For example, this screenshot in my post here: Custom UI: Tiles and another where I created custom graphics with no padding between borders: Custom UI: Tiles
Thx, it worked for me now also.
One Question:
Is it possible to make the card compatible with Android Webview 59 (like in FireOS),
so it is displayed in the Fully Kiosk Browser on a Fire HD Tablet?
This would be awesome!
Thx Wiesl
Wish to have the following functionality, not sure if possible: basically I put a SCENE as the trigger, the SCENE turns ON some lights with a particular scene (brithgness, colours and so on); what would be nice to have is with a following click on the button to turn the LIGHTS off
I do not know if this has already been solved. I am using the button-card to create a panel for turning on and off lights. I would like the color of the icon to be the same as the icon lights would be in the theme I am using. In this case I am talking about the color of the lamps to the left in the picture.
I do not know how to use default color. It is not an option to the card.
If I use color: auto I get white. No color_off gives me gray.
The theme is green when off and yellow that changes depending on brightness. I could off corse specify the green of the theme, but the it does not work when. I change theme.
You probably noticed that the original post here is not up to date anymore. Updating both readme and this post has been tedious so I decided to just post changelog here and update the original post with minimal instructions.
Most of the examples will now be on github only.
Thank you all for your feedback and a special thanks to the users that open PRs.
Last note. If you’re trying to contact me for a bug or a feature request, github is probably the best place
If the theme does not change it I do not need to change “state-icon-active-color”. In the two themes I use I have had to specify “state-icon-color”. This works well and adapts to my changing the theme. Only issue now which of course is an extra is that the lights show different colors depending on brightness, but using “state-icon-active-color” does not allow for that.
Compare the color of the cutlery with the lamps under “Lampor i matsalen”. There must be some way of defining the color the same way as it is done by default in the glance card.
I love the card by the way.
By the way - the tracker still states that it is version 0.0.2 that is available.
