Custom UI: Tiles
Did you find a resolution? I noticed the issue was closed?
Good day, Id like to combine the tiles with the default madia_player. Is it possible to force the tile card to expand to the media player size.
I’ve had luck by just defining how many columns I want and letting it take care of the size. It can make things difficult to properly size icons… but not to hard.
@joshluster thank you. can you tell me what you selected here:
config:
columns: 3
column_width: 75px
row_height: 75px
gap: 15px
trying to get a separate tile to change its color (have no color set and use transparent icons to make them ā€˜float’, I am stuck …
since the tiles run scripts, theres no use for color_on and color_off, and i think i am forced to use the style template below, unfortunately is doesn’t work. :
entities:
          - entity: script.opstart_direct
            image: /local/activities/opstart75.png
            style_template: "if (entities['input_select.activity'].state === 'Opstart') return 'color: #F0C209';"
this is how the tiles show at the moment:
06
my goal is to have the Tile with the script that was selected have a colored background, so i can see which one was selected…
Ive asked on the Tiles Github, but no response or instruction so far.
Hope you can help,
Cheers,
Marius
Stupid mistake - I had copied and pasted the wrong thing into the frontend: section. Mine is now working
config:
columns: 4
row_height: 75px
gap: 0px
color: hsla(0, 0%, 98%, 0)
color_on: hsla(0, 0%, 98%, 0)
color_off: hsla(0, 0%, 98%, 0)
entities:
- entity: script.george_sonos
  image: /local/georgestrait1.png
  column: 1
  row: 1
  column_span: 2
  row_span: 2
- entity: script.brad_sonos
  image: /local/bradpaisly1.png
  column: 3
  row: 1
  column_span: 2
  row_span: 2
- entity: script.country_sonos
  image: /local/country90.png
  column: 1
  row: 3
  column_span: 2
  row_span: 2
- entity: script.garth_sonos
  image: /local/garth1.png
  column: 3
  row: 3
  column_span: 2
  row_span: 2
Can you post your corrected frontend: section. I still can’t get mine working.
My work-around to kind of do this, is to have template switches (or input_booleans linked to automations) that fire whatever you want them to.
Try using ā€˜background-color’ rather than just ā€˜color’ to change the tile colour, I thought ā€˜color’ just changed the primary text.
https://github.com/c727/home-assistant-tiles#entity-config
color is for non-toggle tiles.
what would your suggestion for a template switch look like when used for an input_select in my case? Im confused as it would not have a value on/off?
The style-template would be so very adequate … if one could get it to work that is :wink:
maybe i can create a binary sensor per input_select option and use the latest addition :https://github.com/c727/home-assistant-tiles#changelog or have the input_select also set an input_boolean for that option and use that? Im wondering if i wouldn’t create a loop here.
I was referring to color in CSS land sorry, not this component, give it a go such that the style template has a component that looks like this (this didn’t change secondary text color for me so I didn’t end up using it):
style_template: "if (state === 'on') return 'background-color: hsl(37, 96%, 48%); color: hsl(0, 0%, 98%)'"
I’m using an input select as part of mine as well. Mine uses the tiles Service command via the tiles component (against input_boolean entities which make up the tiles themselves). It looks something like this:
  - entity: input_boolean.tile_tablet_button_alarm_clock
    label_state: input_boolean.alarmclock_status
    label_sec: Alarm Clock
    text_sec_size: '0.7em'
    icon: mdi:alarm
    column_span: 3
    color: 'hsla(0, 0%, 98%, 0)'        #whitetransparent
    color_on: 'hsl(198, 97%, 48%)'      #blue
    color_off: 'hsla(0, 0%, 98%, 0)'    #whitetransparent
    text_color: 'hsl(0, 0%, 0%)'        #black
    text_color_on: 'hsl(0, 0%, 98%)'    #white
    text_color_off: 'hsl(0, 0%, 0%)'    #black
    service: input_select.select_option
      entity_id: input_select.tablet_panel_detail
      option: Alarm Clock
Then I have automations that run based on the input select value (hiding groups and controlling the button):
- alias: Tablet Alarm Clock Panel On
    platform: state
    to: "Alarm Clock"
  - service: group.set_visibility
    entity_id: group.tile_tablet_panel_alarm_clock
      visible: True
  - service: homeassistant.turn_on
    entity_id: input_boolean.tile_tablet_button_alarm_clock
- alias: Tablet Alarm Clock Panel Off
    platform: state
      visible: False
  - service: homeassistant.turn_off
EDIT: Ignore the over-assignment of colours in my customise bit, I’m doing some weird stuff with hiding and showing groups and found this was required to make sure the colour was correctly applied on each group visibility change.
Thank you for your help
well thats what i thought to be using:
       style_template: "if (entities['input_select.activity'].state === 'Opstart') return 'color: #F0C209 ';"
do you spot any mistakes here?
ive got them at least use the color_off, but no tiles is ever turned-on… when i click the action follows fine, the script runs, but the tiles stay Off… do i need anything besides these, iow dont these booleans turn on/off when clicked?:
homeassistant:
  customize:
    input_text.tiles_activity:
      custom_ui_state_card: state-card-tiles
      config:
        columns: auto-fit
        column_width: minmax(75px, 75px)
        color_on: '#F0C209' #'hsl(198, 97%, 48%)'
        color_off: '#555B65'
#        color: "var(--paper-card-background-color)"
#        text_align: center
        text_uppercase: false
        icon_size: 75px
        entities:
          - entity: input_boolean.activity_opstart #script.opstart_direct
            service: script.turn_on
            entity_id: script.opstart_direct
          - entity: input_boolean.activity_opstaan # script.opstaan_direct
            entity_id: script.opstart_opstaan_direct
           # label: Opstaan
            image: /local/activities/opstaan75.png
          - entity: input_boolean.activity_aan_de_slag #script.aan_de_slag_direct
           # label: Aan de slag!
            image: /local/activities/aandeslag75.png
            entity_id: script.opstart_aan_de_slag_direct
          - entity: input_boolean.activity_uit_huis #script.uit_huis_direct
            # label: Uit huis
            image: /local/activities/uithuis75.png
            entity_id: script.uit_huis_direct
          - entity: input_boolean.activity_gym #script.gym_direct
           # label: Gym
            image: /local/activities/gym75.png
            entity_id: script.gym_direct
          - entity: input_boolean.activity_selamat_makan #script.selamat_makan_direct
           # label: Selamat makan
            image: /local/activities/selamatmakan75.png
            entity_id: script.selamat_makan_direct
          - entity: input_boolean.activity_home_theater #script.home_theater_direct
           # label: Home theater
            image: /local/activities/hometheater75.png
            entity_id: script.home_theater_direct
            more_info: script.home_theater_direct
#            style_template: "{% if is_state ('input_select.activity','Home theater') %} color: green {% endif %}"
          - entity: input_boolean.activity_naar_bed #script.naar_bed_direct
          #  label: Naar bed
           image: /local/activities/naarbed75.png
            entity_id: script.naar_bed_direct
input_boolean:
  activity_opstart:
    initial: off
  activity_opstaan:
    initial: off
  activity_aan_de_slag:
    name: Aan de slag
    initial: off
  activity_gym:
    initial: off
  activity_home_theater:
    initial: off
  activity_selamat_makan:
    initial: off
  activity_uit_huis:
    initial: off
  activity_naar_bed:
    initial: off
finally made it , but not with the style_template…
Have made input_booleans for all tiles, and created extra scripts-sections to set these on and off, via an extra group (which makes switching all others off while only the selected is switched on easy)…
figured that when i do have entities now that have an On and Off state, i might as well set the color_on and _off in the tiles grid section.
50
  config:
    columns: auto-fit
    color_on: '#F0C209'
    color_off: "var(--paper-card-background-color)" #'#555B65'
opstart_direct:
  alias: Opstart direct
  sequence:
    - service: input_select.select_option
        entity_id: input_select.activity
        option: Opstart
        entity_id: group.activity_select_booleans
        entity_id: input_boolean.activity_opstart
A lot of extra code, while I still think a style_template for the initial setup should be possible.
Don’t understand why:
style_template: "if (entities['input_select.mode'].state === 'Normal') return 'color: red'; else return 'color: green';"
or
style_template: "{% if is_state ('input_select.mode','Normal') %} color: 'green' {% endif %}"
wont work…
Anyways, thanks for your assistance!
Marius
Glad to see you got it working, what I was trying to explain (poorly) is that you need to do it like this:
style_template: "if (entities['input_select.mode'].state === 'Normal') return 'background-color: red'; else return 'background-color: green';"
INSTEAD OF:
ā€˜color’ in this custom UI and ā€˜color’ in CSS/HTML (which is what style_template applies) are different things.
hi @mynameisdaniel
back again.
background-color working as you described, perfect!
what would i need the color: for coloring the icon and text? is below syntax correct for that?
      - entity: script.audio_auditorium_off
        label_sec: 'Audio A off'
        style_template: "if (entities['sensor.audio_auditorium_state'].state === 'on') return 'background-color: #555B65;color: #F0C209';
                          else return 'background-color: #F0C209; color: #555B65';"
        icon: mdi:music-off
it only colors the icon now, and adding a label_template didn’t help…
01
another tiles question: what could be the reason the text-decoration: line-through doesn’t do anything in
entities:
  - entity: switch.sw_audio_auditorium_template
    label_sec: Auditorium
    icon_template: "if (state === 'on') return 'mdi:music';
                    else return 'mdi:music-off';"
    style_template: "if (state !== 'on') return 'text-decoration: line-through';"
its copied straight from https://github.com/c727/home-assistant-tiles/blob/0303e12376be1b4b1e5f7c6299f1d5565abd729c/configuration.yaml#L101
11
fwiw: the issue of line-throughnot happening is on Safari Mac, not in Chrome. It does occur on the iOS app though.
hi guys, how can I turn off the auto fit-in feature?
I’d like to have 4 columns of tiles, each of the column should have the same width but now the last colum is always auto fitting to the card.
Can someone help?
That’s what I’m getting now:
tiles
EDIT :SOLVED: I had a typo in my config :stuck_out_tongue:
what would be the code for coloring the label_sec in CSS?
this is what i have right now:
  - entity: script.audio_auditorium_on
    label_sec: 'Audio A'
    style_template: "if (entities['sensor.audio_auditorium_state'].state === 'on') return 'background-color: #F0C209; color: #555B65';
                      else return 'background-color: #555B65; color: #F0C209';"
    icon: mdi:music
showing:
21
Need to color the ā€˜Audio A’ depending on the same template as the icon (done with color: )
Hi Guys,
Just wondering if there is a way to completely remove the gap between rows and still have two different buttons: Ch_Up and Ch_Down, see example above,
From This:
To this:
