Custom UI: Weather state card
yweather component should be updated because the best way will be map 31 value to “clear-night” in yweather component and then map this string in custom weather state card.
But for now we can just use your workaround until yweather gets updated, right?
Sure. I created a pull request with yweather component modification.
I think that the UV index will be also useful but right now I don’t know how to get it beacuse it’s not exist in yahoo component.
I had ‘31’ and it wasn’t working but I guess it’s an integer and not a string. Thanks
for me work after reboot my pi3
It’s an integer. After homeassistant restart and clear browser cache it should work.
In the next Home Assistant release this value will be replaced with “clear-night” string.
Weather card update. Main changes:
  1. Now the weather map changes depending on the selected theme. @poebae
  2. Icons of the current weather vary depending on the time of day (the sun component is required)
custom-weather-card.html
<dom-module id='custom-weather-card'>
  <template>
    <style>
      .clear {
        clear:both;
      .card {
        margin:1em auto;
        padding-left: 1em;
        padding-right:1em;
        position: relative;
      .iron-icon {
        height: 18px;
        color: var(--paper-item-icon-color);
      .temp {
        font-weight: 300;
        font-size: 4em;
        color: var(--primary-text-color);
        position: absolute;
        right: 1em;
      .tempc {
        font-weight: 300;
        font-size: 1.5em;
        vertical-align: super;
        position: absolute;
        right: 1em;
        margin-top: -14px;
        margin-right: 7px;
      .variations {
        font-weight:300;
        list-style:none;
        margin-left:-2em;
        margin-top: 3.5em;
      .variations.right {
        float: right;
        margin-left: 0;
        margin-right: 1em;
      .unit {
        font-size:.8em;
      .forecast {
        width:100%;
        margin:0 auto;
        height:9em;
      .day {
        display:block;
        width: 20%;
        float:left;
        text-align:center;
        border-right:.1em solid #d9d9d9;
        line-height: 2;
        box-sizing: border-box;
      .dayname {
        text-transform: uppercase;
      .forecast .day:first-child {
        margin-left: 0;
      .forecast .day:nth-last-child(2) {
        border-right:none;
        margin-right: 0;
      .highTemp {
        font-weight:bold;
      .lowTemp {
        color: var(--secondary-text-color);
      .icon.bigger {
        width: 10em;
        height: 10em;
        margin-top: -4em;
        position: absolute;
        left: 0em;
      .icon {
        width: 50px;
        height: 50px;
        display: inline-block;
        vertical-align: middle;
        background-size: contain;
        background-position: center center;
        background-repeat: no-repeat;
        text-indent: -9999px;
       .weather {
        font-weight: 300;
        font-size: 1.5em;
        text-align:left;
        position: absolute;
        top: -0.5em;
        left: 6em;
        word-wrap: break-word;
        width: 30%;
    </style>
    <div class="card">
      <span class="icon bigger" style="background: none, url(/local/weather_icons/animated/[[nowCond]].svg) no-repeat; background-size: contain;"></span>
      <span class="temp">[[roundedTemp]]</span><span class="tempc">&#176;C</span>
      <span class="weather">[[nowCondIT]]</span>
      <br>
      <span>
        <ul class="variations right">
          <template is="dom-if" if="[[weatherObj.attributes.humidity]]">
            <li><span class="iron-icon"><iron-icon icon="mdi:water-percent"></iron-icon></span> [[weatherObj.attributes.humidity]]<span class="unit"> %</span></li>
          </template>
          <template is="dom-if" if="[[weatherObj.attributes.pressure]]">
            <li><span class="iron-icon"><iron-icon icon="mdi:gauge"></iron-icon></span> [[weatherObj.attributes.pressure]]<span class="unit"> hPa</span></li>
          </template>
          <template is="dom-if" if="[[pressureObj.state]]"> <!-- if weather station doesn't have pressure info, get it from a separate sensor -->
            <li><span class="iron-icon"><iron-icon icon="mdi:gauge"></iron-icon></span> [[nowPressure]]<span class="unit"> hPa</span></li>
          </template>
          <template is="dom-if" if="[[precipationfcObj.state]]">
            <li><span class="iron-icon"><iron-icon icon="mdi:weather-rainy"></iron-icon></span> [[nowPrecipationfc]]<span class="unit" > mm/u (> uur)</span></li>
          </template>
        </ul>
        <ul class="variations">
          <template is="dom-if" if="[[weatherObj.attributes.wind_speed]]">
            <li><span class="iron-icon"><iron-icon icon="mdi:weather-windy"></iron-icon></span> [[windBearing]] [[weatherObj.attributes.wind_speed]]<span class="unit"> m/s</span></li>
          </template>
          <template is="dom-if" if="[[weatherObj.attributes.visibility]]">
            <li><span class="iron-icon"><iron-icon icon="mdi:weather-fog"></iron-icon></span> [[weatherObj.attributes.visibility]]<span class="unit"> m</span></li>
          </template>
          <template is="dom-if" if="[[visibilityObj.state]]"> <!-- if weather station doesn't have visibility info, get it from a separate sensor -->
            <li><span class="iron-icon"><iron-icon icon="mdi:weather-fog"></iron-icon></span> [[nowVisibility]]<span class="unit" > m</span></li>
          </template>
          <template is="dom-if" if="[[precipationObj.state]]">
            <li><span class="iron-icon"><iron-icon icon="mdi:weather-pouring"></iron-icon></span> [[nowPrecipation]]<span class="unit" > mm/u</span></li>
          </template>
        </ul>
      </span>
      <div class="forecast clear">
        <template is="dom-repeat" items="[[forecast]]">
        <div class="day"><span class="dayname">[[item.dayIT]]</span>
          <template is="dom-if" if="[[item.condIcon]]">
          <br> <i class="icon" style="background: none, url(/local/weather_icons/animated/[[item.condIcon]].svg) no-repeat; background-size: contain;"></i>
          </template>
          <template is="dom-if" if="[[item.tempHigh]]">
          <br> <span class="highTemp">[[item.tempHigh]]&#176;C</span>
          </template>
          <template is="dom-if" if="[[item.tempLow]]">
          <br> <span class="lowTemp">[[item.tempLow]]&#176;C</span>
          </template>
        </div>
      </template>
      </div>
    </div>
  </template>
</dom-module>
<script>
(function () {
  'use strict';
  var _WEATHER_TO_ICON_DAY = {
    'cloudy': 'cloudy',
    'fog': 'cloudy',
    'hail': 'rainy-7',
    'lightning': 'thunder',
    'lightning-rainy': 'thunder',
    'partlycloudy': 'cloudy-day-3',
    'pouring': 'rainy-6',
    'rainy': 'rainy-5',
    'snowy': 'snowy-6',
    'snowy-rainy': 'rainy-7',
    'sunny': 'day',
    'windy': 'cloudy',
    'windy-variant': 'cloudy-day-3',
    'exceptional': '!!',
  var _WEATHER_TO_ICON_NIGHT = {
    'cloudy': 'cloudy',
    'fog': 'cloudy',
    'hail': 'rainy-7',
    'partlycloudy': 'cloudy-night-3',
    'rainy': 'rainy-5',
    'snowy': 'snowy-6',
    'sunny': 'night',
    'windy': 'cloudy',
    'windy-variant': 'cloudy-night-3',
  var _WEATHER_TO_NAME = {
    cloudy: 'Cloudy',
    fog: 'Fog',
    hail: 'Hail',
    lightning: 'Lightning',
    'lightning-rainy': 'Lightning',
    partlycloudy: 'Partly cloudy',
    pouring: 'Pouring',
    rainy: 'Rainy',
    snowy: 'Snowy',
    'snowy-rainy': 'Rain and snow',
    sunny: 'Clear sky',
    windy: 'Windy',
    'windy-variant': 'Windy',
    exceptional: '!',
  var _DEGREE_TEXT = [
    'N', 'NNO', 'NO', 'ONO', 'O', 'OZO', 'ZO', 'ZZO',
    'Z', 'ZZW', 'ZW', 'WZW', 'W', 'WNW', 'NW', 'NNW', 'N'
  var _DAY_TO_DAY = {
    Mon: 'MON',
    Tue: 'TUE',
    Wed: 'WED',
    Thu: 'THU',
    Fri: 'FRI',
    Sat: 'SAT',
    Sun: 'SUN',
  Polymer({
    is: 'custom-weather-card',
    properties: {
      hass: {
        type: Object,
      stateObj: {
        type: Object,
      weatherObj: {
        type: Object,
        observer: 'checkRequirements',
        computed: 'computeWeatherObj(hass, stateObj)',
      sunObj: {
        type: Object,
        computed: 'computeSunObj(hass, stateObj)',
      pressureObj: {
        type: Object,
        computed: 'computePressureObj(hass, stateObj)',
      visibilityObj: {
        type: Object,
        computed: 'computeVisibilityObj(hass, stateObj)',
      precipationObj: {
        type: Object,
        computed: 'computePrecipationObj(hass, stateObj)',
      precipationfcObj: {
        type: Object,
        computed: 'computePrecipationfcObj(hass, stateObj)',
    computeWeatherObj: function (hass, stateObj) {
      return stateObj && stateObj.attributes && stateObj.attributes.config && stateObj.attributes.config.weather ? hass.states[stateObj.attributes.config.weather] : null;
    computeSunObj: function (hass, stateObj) {
      return stateObj && stateObj.attributes && stateObj.attributes.config && stateObj.attributes.config.sun ? hass.states[stateObj.attributes.config.sun] : null;
    computePressureObj: function (hass, stateObj) {
      return stateObj && stateObj.attributes && stateObj.attributes.config && stateObj.attributes.config.pressure ? hass.states[stateObj.attributes.config.pressure] : null;
    computeVisibilityObj: function (hass, stateObj) {
      return stateObj && stateObj.attributes && stateObj.attributes.config && stateObj.attributes.config.visibility ? hass.states[stateObj.attributes.config.visibility] : null;
    computePrecipationObj: function (hass, stateObj) {
      return stateObj && stateObj.attributes && stateObj.attributes.config && stateObj.attributes.config.precipation ? hass.states[stateObj.attributes.config.precipation] : null;
    computePrecipationfcObj: function (hass, stateObj) {
      return stateObj && stateObj.attributes && stateObj.attributes.config && stateObj.attributes.config.precipationfc ? hass.states[stateObj.attributes.config.precipationfc] : null;
    getForecastArray: function () {
      if (!this.weatherObj.attributes.forecast) {
        return [];
      var data = this.weatherObj.attributes.forecast;
      var forecast = [];
      var prevDay = '';
      for (var i = 0; i < data.length; i++) {
        var day = new Date(data[i].datetime).toString().split(' ')[0];
        if (day != prevDay) {
          if (data[i].max_temp) {
            var tempHigh = Math.round(data[i].max_temp * 10) / 10;
          } else {
            var tempHigh = Math.round(data[i].temperature * 10) / 10;
          if (tempHigh == 0) {
            tempHigh = '0'; // otherwise the value 0 will not be shown on the weather card
          var tempLow = Math.round(data[i].templow * 10) / 10;
          if (tempLow == 0) {
            tempLow = '0'; // otherwise the value 0 will not be shown on the weather card
          var condIcon = _WEATHER_TO_ICON_DAY[data[i].condition];
          var dayIT = _DAY_TO_DAY[day];
          forecast.push({dayIT:dayIT, tempHigh:tempHigh, tempLow:tempLow, condIcon:condIcon});
          prevDay = day;
        } else {
          } else {
          var tempLow = Math.round(data[i].tempLow * 10) / 10;
          if (tempLow > forecast[forecast.length-1].tempHigh) {
            forecast[forecast.length-1].tempHigh = tempLow;
          if (tempHigh > forecast[forecast.length-1].tempHigh) {
            forecast[forecast.length-1].tempHigh = tempHigh;
          if (!forecast[forecast.length-1].tempLow) {
            forecast[forecast.length-1].tempLow = tempHigh;
          if (tempHigh < forecast[forecast.length-1].tempLow) {
          if (tempLow < forecast[forecast.length-1].tempLow) {
            forecast[forecast.length-1].tempLow = tempLow;
      return forecast;
    checkRequirements: function () {
      if (!this.weatherObj) {
        return;
      if (this.nowSun == 'above_horizon') {
	    this.nowCond = _WEATHER_TO_ICON_DAY[this.weatherObj.state];
      if (this.nowSun == 'below_horizon') {
	    this.nowCond = _WEATHER_TO_ICON_NIGHT[this.weatherObj.state];
      this.nowCondIT = _WEATHER_TO_NAME[this.weatherObj.state];
      if (this.pressureObj != null) {
        this.nowPressure = this.pressureObj.state;
      if (this.sunObj != null) {
        this.nowSun = this.sunObj.state;
      if (this.visibilityObj != null) {
        this.nowVisibility = this.visibilityObj.state;
      if (this.precipationObj != null) {
        this.nowPrecipation = this.precipationObj.state;
      if (this.precipationfcObj != null) {
        this.nowPrecipationfc = this.precipationfcObj.state;
      if (this.weatherObj.attributes.temperature) {
        this.roundedTemp = Math.round(this.weatherObj.attributes.temperature);
        if (this.roundedTemp == 0) {
          this.roundedTemp = '0'; // otherwise the value 0 will not be shown on the weather card
		if (this.roundedTemp > 0) {
          this.roundedTemp = '+'+this.roundedTemp;
      if (this.weatherObj.attributes.wind_bearing) {
        this.windBearing = this.windBearingToText(this.weatherObj.attributes.wind_bearing);
      this.forecast = this.getForecastArray().slice(0, 5);
    windBearingToText: function (degree) {
      // return _DEGREE_TEXT[((parseInt(degree) + 5.63) / 11.25) | 0];
      return _DEGREE_TEXT[(parseInt((degree + 11.25) / 22.5))];
</script>
configuration.yaml
homeassistant:
  customize:
    input_boolean.weather:
      custom_ui_state_card: custom-weather-card
      config:
        weather: weather.yweather
        sun: sun.sun
Screenshots
pic-1
pic-2
PS. Visibility icon not displayed bacause my weather component not support it
Awesome, thank you!
ok, so I am missing the large icon next to the current temp but the forecast shows up. Tried a reboot and a forced cache refresh to no avail. What am I missing here folks?
Check the paths to the icons (line 112). The path must be the same as in line 152.
</style>
<div class="card">
What is the state of the yweather component now? (sunny, cloudy e.t.c.)
Thanks @Yevgeniy
and
look the same to me… right?
Current condition in the yWeather is showing a cloudy symbol like so…
Capture
not sure how I can actually see the value though as the state just reports a value of:
[object Object]
any ideas what to check for?
Clear your browser’s cache. Not ctrl + F5 but in the browser settings
still nothing showing… I must have something missing. I will check the config again
finally found it… for some reason on 4th time re-reading it I was missing the sun part of the config:
sun: sun.sun
get many of these:
ceback (most recent call last):
  File "/usr/lib/python3.6/asyncio/tasks.py", line 180, in _step
    result = coro.send(None)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 222, in async_update_ha_state
    attr = self.state_attributes or {}
  File "/usr/lib/python3.6/site-packages/homeassistant/components/weather/__init__.py", line 113, in state_attributes
    ATTR_WEATHER_HUMIDITY: round(self.humidity)TypeError: type NoneType doesn't define __round__ method
could this come from the custom_weather card??
No. This come from your weather component. Which one do you use?
How I remove yweather window? how to rename input boolean window and can remove plus symbol from temperature?
Yweather, buienradar and Open weather map.
It’s strange. These components do not use rounding for humidity
could it be the filter sensor:
- platform: filter
  name: "Filtered humidity living"
  entity_id: sensor.luchtvochtigheid_living
  filters:
    - filter: outlier
      window_size: 4
      radius: 4.0
    - filter: lowpass
      time_constant: 10
      precision: 2
also have the Mold sensor, but that never gave issues:
- platform: mold_indicator
  indoor_temp_sensor: sensor.temperatuur_living
  indoor_humidity_sensor: sensor.luchtvochtigheid_living
  outdoor_temp_sensor: sensor.br_temperature
  calibration_factor: 1.16
I did only notice the error since updating to 65.5but am not positively certain thats the reason. Theres another thread I’ve asked the question but it never followed through unfortunately.
