Thank you, Andrey, works like a charm now!
@morrelli43 Do you mind sharing the script behind your tv volume control?
Im trying to use your same custom card to control my tv to
Sorry for the delay!
I have a harmony hub, so I just needed to pass through the command for the volume button to the hub.
This is all I had to do.
tvvolumeup:
sequence:
- service: remote.send_command
entity_id: remote.harmony_hub
device: "30557844"
command: "VolumeUp"
I hope this helps you!
Hello @JesseWebDotCom.
Could you please share your code for fan.
I was following guides in this thread and tried to build custom card for fan but can’t even make it appear.
This stopped working for me, so I stopped using it. I’m currently using this: https://community.home-assistant.io/t/custom-ui-tiles/
I would like to be able to control le speed level of my dyson link fan with a slider on custom UI. And if possible to add a button for the oscillate.
I manged to make the sliders works for my light bulbs and to make the slider appaer next to the dyson fan like i did with the lights, but the fan slider is not working.
Do you have any suggestions?
My custom_glob:
fan.*:
custom_ui_state_card: state-card-custom-ui
state_card_mode: single-line
slider_theme:
min: 0
max: 10
pin: true
off_when_min: true
report_when_not_changed: false
Little help plz
still wing it here getting my head around it slowly I think
I put the
fan-model.html into the www folder
and the
state-card-with-speed.html into the www\custom_ui folder
state-card-custom_fan.html into the www\custom_ui folder
now the bit im lost in
I have this in my Fan.yaml
- platform: mqtt
state_topic: "home/Hall_fan/Switch"
command_topic: "home/Hall_fan/cmd"
payload_on:"DONT KNOW WHAT TO PUT HERE"
payload_off:"DONT KNOW WHAT TO PUT HERE"
optimistic: false
qos: 0
retain: true
in my custom:
fan.hall_fan:
icon: mdi:fan
custom_ui_state_card: custom_fan
when I look in <>
I see
so that telling me HA is seeing it I Think
and in my group i have
Hall:
entities:
- switch.Hall_light
- fan.hall_fan
Also in the Frontend I added this
frontend:
themes: !include_dir_merge_named themes/
extra_html_url:
- /local/custom_ui/state-card-custom-ui.html
- /local/custom_ui/state-card-with-speed.html
- /local/custom_ui/state-card-custom_fan.html
extra_html_url_es5:
- /local/custom_ui/state-card-custom-ui-es5.html
it does not show
what step did i miss
One error I see in your configuration is where you have:
fan.hall_fan:
icon: mdi:fan
That last line should be:
custom_ui_state_card: state-card-custom_fan
…because it should match the name of the html file you have in the custom_ui folder.
thanks ill have a look when home
hello @myle Hello, worked for you? what your HA version?
In my 0.53.1 not work
Sort of working Will update when it is
Hi!!
I just a newbie on making my room with HA and I really happy with all your help ![]()
The Fan is the first one I connected to HA and remote it via boardlink.
I took 2 week to custom this Fan UI as @kylerw share in this topic and finally it work… However, when I click on Low/Med/High and I got the error
Unable to find service fan/set_speed 1:25 PM core.py (WARNING)
I know I miss something… please anyone help me with this ![]()
Thanks for your help
hey buddy, is there a way to ‘intercept’ the speeds, and have them turn on a switch. not great on the code side.
i have fan power running through a z-wave in wall microcontroller
and the fan speeds i used this RF Ceiling Fan Remote Hack
so on off is one switch, and the speeds translate to turning on a different switch for each speed.
thanks in advance
I don’t think it would be a problem to update to support that setup - I’ve since stopped using this so I’m not sure I’m the best person to help. Sorry!
no worries, appreciate the response
very handy bit of code, thanks
if i wanted to do the same for locks, i thought i could just look at states.lock
could I simply change all occurances of this:
{%-for state in states.binary_sensor
if(state.attributes.device_class=="motion" and state.state=="on")-%}
to this:
{%-for state in states.lock
if(state.state=="unlocked")-%}
i thought it wasnt working, i had something else wrong…so this works for locks - VERY nicely (well with 2 doors unlocked, may run out of room with 3) - Thanks again for the code @jamesdawson3
sensors:
locks_summary:
value_template: >
{%-if loop.last-%}
{%-if loop.index > 0-%}
{%-for state in states.lock if(state.state =="unlocked")-%}
{{state.name}}{%-if not loop.last -%}{%-if(loop.index+1==loop.length)%} & {%else%}, {%endif-%}{%-else%} Door Unlocked{%endif-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
All Locked
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:lock-open
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:lock
{%-endfor-%}
Mind saying what you’re using in place of this? I’m looking to create something similar to what you did and am wondering if you found a “better” way
I’m using CustomUI but only to display the speed. I use Google Home to control the speed should I need to change it, generally. I can still open the detail modal for the Fan and adjust it there as well.
OK, thanks. I’m pretty new to HA and still trying to digest all the different options. I’ve got a slightly different requirement. I’m planning on using a Sonoff 4CH Pro w/ Tasmota firmware to control a shop air filtration system (AFS). I’m wiring the Sonoff directly into the motor so I need to development scripts/automation/scenes? to set/unset the different channels based on what speed I want.
I have an Amazon Echo in the shop which I tried to use with a shop vacuum but when the vacuum is on Echo can’t hear the commands so voice control isn’t really a viable option for me unfortunately. The AFS might be a different case though since generally you turn it on for a set amount of time so part of my script might be to default to turn off after a fixed amount of time and then voice control might be an option.
So many choices…
