Hi all,
I can’t get the custom updater working. I followed the guide, placed the custom_updater.py here:
\\xxx.xxx.xxx.xxx\config\custom_components\custom_updater.py
… and added the custom_updater: to my configuration.yaml file.
But here is what I get when I reboot my Home Assistant, after it fails to check the configuration.
INFO:homeassistant.util.package:Attempting install of colorlog==3.1.4
Testing configuration at /config
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/local/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 207, in check
res['components'] = check_ha_config_file(hass)
File "/usr/local/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 340, in check_ha_config_file
component = loader.get_component(hass, domain)
File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 92, in get_component
module = importlib.import_module(path)
File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 674, in exec_module
File "<frozen importlib._bootstrap_external>", line 781, in get_code
File "<frozen importlib._bootstrap_external>", line 741, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/custom_updater.py", line 7
<!DOCTYPE html>
SyntaxError: invalid syntax
Fatal error while loading config: invalid syntax (custom_updater.py, line 7)
Failed config
General Errors:
- invalid syntax (custom_updater.py, line 7)
Successful config (partial)
Huh??
