I have placed the two files from https://github.com/custom-components/custom_updater/tree/master/custom_components/custom_updater in config\custom_components\custom_updater
In configuration.yaml:
custom_updater:
component_urls:
- https://raw.githubusercontent.com/xirixiz/Home-Assistant-Sensor-Afvalwijzer/master/custom_updater.json
- https://raw.githubusercontent.com/peternijssen/lovelace-postnl/master/tracker.json
In ui-lovelace.yaml:
resources:
- url: /customcards/monster-card/monster-card.js
type: js
- url: /customcards/github/custom-cards/tracker-card.js?track=true
type: module
- url: /customcards/slider-entity/slider-entity-row.js
type: js
- url: /customcards/postnl-card.js
type: module
An in ui-lovelace.yaml:
cards:
- type: custom:tracker-card
title: Updates
trackers:
- sensor.custom_card_tracker
- sensor.custom_component_tracker
Error log:
Log Details (ERROR)
Fri May 03 2019 09:42:36 GMT+0200 (Midden-Europese zomertijd)
'local_location'
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1138, in async_call
self._execute_service(handler, service_call))
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1160, in _execute_service
await handler.func(service_call)
File "/config/custom_components/custom_updater/__init__.py", line 110, in check_all_service
await components_controller.cache_versions()
File "/config/custom_components/custom_updater/__init__.py", line 222, in cache_versions
information = await self.pyupdate.get_sensor_data(True)
File "/config/deps/lib/python3.7/site-packages/pyupdate/ha_custom/custom_components.py", line 64, in get_sensor_data
local_file = self.base_dir + str(component['local_location'])
KeyError: 'local_location'
Any tips what I am missing?
