Since the last update of custom updater, it shows me update available after each ha restart.
And of course there is no update available.
Does someone else have that issue too?
custom updater version 4.2.15
ha 0.88.1
ha 0.88.1
ha 0.88.2 was released yesterday.
Perhaps there really IS an update this time
But custom updater doesnāt look for the ha version. It only looks for custom components and lovelace cards.
Not 100% sure about this, but I believe it looks for versions in two places ā in the local copy of the custom component, and in a centrally maintained json file. The json file (I think) is only updated every hour or so. So, if you havenāt updated in a while, itās possible there may have been more than one update to a component. And if you just happen to update during that period before the json file is updated, itās possible to get a newer version of the component than the json file thinks exists. Then when you check, it will say thereās an update, but if you look closely, the āremoteā version will actually be less than the local version. If you wait long enough, and then run the custom_updater.check_all service, or just wait until it runs automatically, the situation will clear itself up. Iām pretty sure Iāve seen this happen.
In case I didnāt explain that very well, hereās a concrete example. Say you have version 1.0.0 of some component. Then at some point 1.1.0 comes out, but you donāt update yet. Before long the json file will be updated to say 1.1.0 is the latest. Then 1.2.0 comes out, and while the json file still says 1.1.0 you check for updates. It will say you have 1.0.0 and 1.1.0 is available. So you update. But now you have 1.2.0. So when you check it will say the latest is (still) 1.1.0 and the local version is 1.2.0. Since they donāt agree it says an update is available. Now, if you wait long enough, it will eventually say the latest is 1.2.0, which agrees with what you have, so it no longer says an update is available.
Thanks. The thing is that it only shows āupdate availableā after a restart.
If I delete the persistant notification and check manually again, it does not show āupdate availableā again.
Restart and it shows up again.
I already deleted the old custom_updater.py file and replaced it with the newest one.
Still the same issue.
All my cards and components show as newest version.
A persistent notification is not a part of that component (yet), so if that happens you have an automation that is not working correctly.
Thanks for pointing me in that direction, I forgot that I setup the persitant notification myself.
This is the binary sensor that worked before, now it seems like has_update isnāt empty any more, so this sensors stays true. It reports āfalseā.
sensors:
custom_component_has_no_update:
value_template: "{{ states.sensor.custom_component_tracker.attributes.has_update == [] }}"
had it from here:
https://github.com/custom-components/custom_updater/issues/68
I indeed had a faulty automation
You can see the binary sensor above.
And this was my automation trigger
platform: state
entity_id: binary_sensor.custom_component_has_no_update
to: 'on'
And of course this has trigger when it goes to āoffā, because its true when there is no update.
I donāt know why (i had the feelling) that it worked before. It did show a persistant not when there was a new update.
Donāt know whyā¦
Iām also attempting to delete a custom updater install from hass.io 88.2. Iāve deleted custom.updater.py from custom_components, the pycache file, removed custom_updater: from configuration.yaml, and removed the resource from the .storage/lovelace file. Iām still getting this error on restart:
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /config
Failed config
General Errors:
- Component not found: custom_updater
Successful config (partial)
What have i missed?
I found the problem.
So you deleted that files withour replacing them with the new versions?
If yes you probably have to comment out those lines in the configuration.yaml too. Else it will search for that component.
Edit: Missen the āI found the problemā. Maybe you want to share your issue.
