Custom Vesync component add device support manually
I dont know if this is even possible or not but I currently have two Vesync Devices. 1. Core400s , 2. LUH-O451S-WEU. As the official Integration does not currently support a lot of Vesync Humidifiers i’ve looked for Custom Integrations and found this one GitHub - vlebourl/custom_vesync: Custom VeSync component for Home Assistant.
Unfortunately they only support the US Version (LUH-O451S-WUS) of the Device and not the EU. But because these Devices are basically identical as far as i can tell i think it should work for the EU Version as well. The Integration relies on GitHub - webdjoe/pyvesync: pyvesync is a python library to manage Etekcity & Levoit smart devices which is responsible for the Vesync API.
Now to my question. Can i “easily” integrate the EU Device into the Code?
I am no programmer, but as far as i can see it boils down to vesyncfan.py in which there is a list of devices. Because i found multiple Instances of other devices which have their EU Version in the List as well, i think i could just add the LUH-O451S-WEU to this List. However i don’t know how i could do this.
I’ve tried referencing the URL of the forked Repo, which didn’t work. I’ve tried downloading the Forked Repo and putting in in /config/custom_components/vesync which didn’t work either. When the custom Integration starts it doesn’t find the repository.
TLDR: I opened an issue on the pyvesync repo and it should be added in the next release ( > pyvesync-2.1.7).
For anyone with the same issue if the EU Version is not added.
You have to mount the HA Docker Volume using the advanced Terminal or via the Host OS Running HA.
Then find the pyvesync package and add the Line to the models.
