Customising the BOM Weather and lovelace - now in HACS
As @Nicko1 said. You get to choose it when adding the integration, but it looks like you have the entities for enough days as you have the temperatures. It looks like you have this entry set wrong.
Get to that page using this icon on the main page.
yep, I reinstalled BOM integration and its working now
I have released 0.0.3 of the platinum version of the card. The changes are mostly aimed at people that are not using the BoM integration and only have the weather.xxxxx type entity available.
Once again simple questions welcome here but for more complex issues please create a github issue.
After updating to 0.0.3, I now get a lovelace error card & the custom card is no longer available. Tried redownloading. Also deleting and reinstalling. My existing, now-failing card starts with card_config_version: 4
Nothing stands out in my log.
Same here. 0.0.3 does not work. Reloading 0.0.2 does work.
HA 2022.7.1 installed.
@Jefe @curtis-r try restarting HA. That fixed it for me as odd as it sounds and then the F12 and right-click refresh & select clear cache and hard reset.
Sorry, didn’t work.
I had to restart home assistant, reload 0.0.2, refresh then reload the latest version.
Updating HACS to 1.26 seems to have fixed the issue of loading Platinum 0.0.3 :clap:.
BTW, loving the Platinum Weather Card! Thanks to the Devs.
Same here. Didn’t even notice there was a HACS update. My bad. Also had to redownload Platinum to get working. Thanks.
Using your Sensor code (and modifying it with my local NWS), got everything working. Thanks. A new issue is that my “local” NWS is actually far enough away for the information to be quite inaccurate. Any plans to allow other weather service data, such as OpenWeather?
Regarding OpenWeather, I don’t have any plans currently, but others might.
In the meantime, try to put in just your latitude and longitude entries when setting up the NWS integration, and don’t fill in the reporting station ID. It might come up with a station closer to you, or it might report local grid data that’s more accurate.
If you do the above, you’ll need to poke around Developer Tools and look at the weather entirely to see how it’s named. Then the weather.yaml file can be appropriately modified with what you found.
For those that have been having problems with 0.0.3 please update HACS to 1.26.0 and reinstall. A minor issue was fixed in HACS after I reported a problem yesterday.
Hi, I have HACS 1.26.1 and Home Assistant 2022.7.1 installed and for weather forecast I use OpenWeatherMap (https://openweathermap.org/).
After install Platinum Weather Card 0.0.3 everything works fine except minimum temperature forecast (please see image below).
I tried to use my weather.openweathermap entity with official Home Assistant Weather card and it seems it works.
Do you know, where the problem could be ?
Adam
Update.
I removed OpenWeatherMap integration → restart and add it again and now everything works well.
Platinium Weather card is really good
It would be great if we can add the Wind speed in the forecast
Hi there, one more problem here.
After all set up - informations about weather forecast seems to be correct, but relevant icons seems to be incorect / shifted (icon for particular day condition shows condition of day after).
Do you have a crystal ball? Does your weather integration provide those?
For some reason the Platinum card isn’t showing my forecast max temp. Any ideas?
BoM card (most recent DavidFW1960 version)
code
type: custom:bom-weather-card
title: BOM Weather
entity_current_conditions: sensor.morley_icon_descriptor_0
entity_temperature: sensor.perth_temp
entity_forecast_high_temp_1: sensor.morley_temp_max_1
entity_forecast_high_temp_2: sensor.morley_temp_max_2
entity_forecast_high_temp_3: sensor.morley_temp_max_3
entity_forecast_high_temp_4: sensor.morley_temp_max_4
entity_forecast_high_temp_5: sensor.morley_temp_max_5
entity_forecast_icon_1: sensor.morley_icon_descriptor_1
entity_forecast_icon_2: sensor.morley_icon_descriptor_2
entity_forecast_icon_3: sensor.morley_icon_descriptor_3
entity_forecast_icon_4: sensor.morley_icon_descriptor_4
entity_forecast_icon_5: sensor.morley_icon_descriptor_5
entity_forecast_low_temp_1: sensor.morley_temp_min_1
entity_forecast_low_temp_2: sensor.morley_temp_min_2
entity_forecast_low_temp_3: sensor.morley_temp_min_3
entity_forecast_low_temp_4: sensor.morley_temp_min_4
entity_forecast_low_temp_5: sensor.morley_temp_min_5
entity_summary_1: sensor.morley_short_text_1
entity_summary_2: sensor.morley_short_text_2
entity_summary_3: sensor.morley_short_text_3
entity_summary_4: sensor.morley_short_text_4
entity_summary_5: sensor.morley_short_text_5
entity_sun: sun.sun
entity_daytime_high: sensor.morley_temp_max_0
entity_daytime_low: sensor.morley_temp_min_0
entity_wind_bearing: sensor.perth_wind_direction
entity_wind_speed: sensor.perth_wind_speed_kilometre
entity_wind_gust: sensor.perth_gust_speed_kilometre
entity_humidity: sensor.perth_humidity
entity_apparent_temp: sensor.perth_temp_feels_like
entity_daily_summary: sensor.morley_extended_text_0
entity_pop: sensor.morley_rain_chance_0
entity_pop_intensity: sensor.perth_rain_since_9am
entity_possible_today: sensor.morley_rain_amount_range_0
entity_pos_1: sensor.morley_rain_amount_range_1
entity_pos_2: sensor.morley_rain_amount_range_2
entity_pos_3: sensor.morley_rain_amount_range_3
entity_pos_4: sensor.morley_rain_amount_range_4
entity_pos_5: sensor.morley_rain_amount_range_5
entity_pop_1: sensor.morley_rain_chance_1
entity_pop_2: sensor.morley_rain_chance_2
entity_pop_3: sensor.morley_rain_chance_3
entity_pop_4: sensor.morley_rain_chance_4
entity_pop_5: sensor.morley_rain_chance_5
entity_fire_danger_summary: sensor.morley_fire_danger_0
large_icon_left_position: 0px
large_icon_top_margin: '-3.2em'
locale: en
old_daily_format: false
refresh_interval: 60
separator_top_margin: 6em
show_beaufort: false
show_decimals: false
show_separator: false
static_icons: false
summary_font_size: 0.8em
slot_l1: daytime_high
slot_l2: daytime_low
slot_l3: wind
slot_l4: pressure
slot_l5: sun_next
slot_r1: pop
slot_r2: humidity
slot_r3: uv_alert
slot_r4: fire_danger
slot_r5: sun_following
summary_top_padding: 2em
sunset: true
temp_font_size: 4em
temp_font_weight: 300
temp_right_pos: 0.85em
temp_top_margin: 0px
temp_uom_right_margin: 7px
temp_uom_top_margin: '-12px'
time_format: 24
tooltip_bg_color: rgb( 75,155,239)
tooltip_border_color: rgb(255,161,0)
tooltip_border_width: 1
tooltip_caret_size: 5
tooltip_fg_color: '#fff'
tooltip_left_offset: -12
tooltip_width: 110
tooltips: true
Platinum version with same sensors etc.
code
Entity_forecast_max: sensor.morley_temp_max_0
daily_forecast_days: 5
entity_forecast_min: sensor.morley_temp_min_0
entity_sun: sun.sun
extended_use_attr: false
option_locale: en
option_time_format: 24hour
option_tooltips: true
section_order:
  - title
  - overview
  - extended
  - slots
  - daily_forecast
show_section_title: false
show_separator: true
slot_l1: forecast_max
slot_l3: wind
slot_l4: pressure
slot_l5: sun_next
slot_l6: remove
slot_l7: remove
slot_l8: remove
slot_r1: pop
slot_r2: humidity
slot_r3: uv_summary
slot_r6: remove
slot_r7: remove
slot_r8: remove
type: custom:platinum-weather-card
The entity is fine, hence it works in the old card.
Does Brendan’s weather integration have a wind bearing in degrees (as opposed to cardinal points)?
Just wondering before I delete the integration and set it up again to see.
