I do see the icons got installed in with the platinum version. but why do I not see them in Lovelace?
See also they are renamed… here is a sample of my directory
Simon @theRat see that the Thermal Comfort integration I use in HACS has the icons as a separate repo probably to get over the limitation.
@xxharry maybe redownload and you should get the icons working again
because they need to be renamed (automatic if you install the beta)
I redownloaded 0.0.2 but nothing changed. was this the version you referring to?
no the beta (enable betas on the download) 0.0.3b1 is latest I think
I’d guess you haven’t configured the entities to use for various parts of the card.
The circled item selects the entity to use.
There is a similar one on the daily forecast page.
clear the cache F12 and right click refresh icon clear cache and hard reload. Failing that restart Home Assistant as well
Or what Simon said hahaha
this is it. how do I get those entities? I have nothing that says “icon descriptor”
Can you open the code editor for the card and cut/paste the yaml here… that will make it easier to see what you are missing
It will be in the overview section
entity_apparent_temp: sensor.kilmore_gap_temp_feels_like
entity_current_conditions: sensor.kalkallo_mdi_icon_0
entity_daily_summary: sensor.kalkallo_extended_text_0
entity_fire_danger_summary: sensor.kalkallo_fire_danger_0
entity_forecast_high_temp_1: sensor.kalkallo_temp_max_1
entity_forecast_icon_1: sensor.kalkallo_temp_max_1
entity_forecast_low_temp_1: sensor.kalkallo_temp_min_1
entity_forecast_max: sensor.kalkallo_temp_max_0
entity_forecast_min: sensor.kalkallo_temp_min_0
entity_pop: sensor.kalkallo_rain_chance_0
entity_possible_today: sensor.kilmore_gap_rain_since_9am
entity_temperature: sensor.kilmore_gap_temp
entity_todays_fire_danger: sensor.kalkallo_fire_danger_0
entity_todays_uv_forecast: sensor.kalkallo_uv_category_0
entity_uv_alert_summary: sensor.kalkallo_uv_category_0
entity_wind_bearing: sensor.kalkallo_uv_start_time_6
entity_wind_gust: sensor.kilmore_gap_gust_speed_kilometre
entity_wind_speed: sensor.kilmore_gap_wind_speed_kilometre
extended_use_attr: false
option_icon_set: new
option_static_icons: false
option_time_format: 24hour
option_today_decimals: true
section_order:
- title
- overview
- extended
- slots
- daily_forecast
show_decimals: true
show_section_title: true
show_separator: true
slot_l1: forecast_max
slot_l2: forecast_min
slot_l3: wind
slot_l4: remove
slot_l5: sun_next
slot_l6: remove
slot_l7: remove
slot_l8: remove
slot_r1: popforecast
slot_r2: remove
slot_r3: uv_summary
slot_r4: fire_summary
slot_r5: sun_following
slot_r6: remove
slot_r7: remove
slot_r8: remove
type: custom:platinum-weather-card
what is the state of that entity in dev-tools?
But the wind bearing looks to be an incorrect entity as well
there should be an entity with a state of rainy there somewhere
You should have an entity named like this (swap pearce for kalkallo)
If you don’t have it then I suspect you didn’t tick the option when installing the BoM integration. To add it, delete the BoM integration and reinstall and make sure you select the right options. Also make sure you use the same names so that they all comes back the same.
yep that got sorted. now what do I do about the forecast days down the bottom? and what would the correct windbearing entity be?
@Xxharry try this mate
When you setup the BOM integration do you remember how many days forecast you selected?
It might pay to reinstall BOM first and select everything to provide you with all the necessary entities.
where do I get the option to select the number of days forecast? I am not having issues with displaying the forecast, just the icons
